02-09-2013, 05:33 PM
Spoiler Control Indicator Switch
I purchased this from a Germany eBay seller for $90 shipped. It is pretty cool. You can manually operate the spoiler from the switch which installs on the dash and matches the other switches there. When the spoiler is down, the light is unlit. As it raises or lowers it blinks and when it is fully raised the red light stays lit.
This may seem unnecessary, but in Los Angeles you can go from under 55 MPH to over 75 MPH numerous times during a commute. With this I can easily manually raise it and when I am parking I am reminded to lower it due to the red light.
Spoiler Control Indicator Switch Porsche Carrera Turbo 4S Boxster s 986 996 | eBay
1995 Porsche C4 Cab
02-09-2013, 05:42 PM
still plays with cars...
That's a neat little toy, and apparently really easy to hook up.
It's on my things-I-want-when-I-have-money-left-after-fixing-all-the-broken-stuff-list.
Six speed 2000 Boxster S
02-10-2013, 05:21 AM
Chuck. I also thought that was a very nice upgrade and ordered two for the 986 and the 996 since you can not see the spoiler on either of them from inside. They came with very detailed instructions, but when I tried to install the one in the boxster I could not get the wires to make contact in the dash connectors. The little blades on the wires that slide down beside the existing wires don't seem long enough to get in far enough to make contact. I made several emails to the seller in germany and he seemed to try to be helpful, but basicly just told me to do what was already indicated in the printed instructions, which already was not working.
Did you have any problems getting yours to make contact and do you have any tips. After several tries and no success on the boxster I just gave up and have not tried the 996 yet. I suppose I could splice into the appropriate wires back behind the dash connectors, but I really do not want to do that. It just appears to me that the small flat blades on the wire ends are about 1/4 inch too short to make contact.
02-10-2013, 08:03 AM
Even though the install is straight forward, it was challenging. I had no success my first attempt and tried to tap into the wires as they left the connector, but for some reason this did not work either. By the time I was done with my first attempts I had broken off two of the tips from the wires. I sent the unit back to Germany and the seller sent me a new one. This time I took my time and straighten out all of the wires in the connector (they make a 90 degree turn as they come out of the connector). I installed the green wires first as they are the most difficult. The other three are pretty easy. They simply slide in on the outside portion of the connector.
I think the key is the straighten out of the wires so you can see what your doing and taking your time.
1995 Porsche C4 Cab
02-10-2013, 09:28 AM
sounds like it was almost as frustrating for you as it was for me. I will try it again some day when I have more patience and feel up to the challenge.
04-19-2014, 02:00 PM
Earlier today I installed the version that simply functions as an indicator. The green wire is certainly the hardest of the lot because the two wires on it are a heavier gauge. I understand why they used a beefier gauge wire, but it made things more difficult. The other wires installed easily. Chuck's tip is a good one.
11-26-2015, 04:41 PM
Problems...
I finally got around to installing the switch; there is a problem. Spoiler goes up and down correctly. The light in the switch stays on when the spoiler is up.
But; the switch light does not flash as the spoiler raises, but does flash when the turn signals are used.
Can anyone pinpoint the problem ?
11-26-2015, 06:21 PM
Have one too....still have to install it. I had assumed that it would work correctly
986 00S
11-27-2015, 04:48 AM
Where did you buy them ?
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
11-27-2015, 06:44 AM
When I first installed mine, all of the lights flashed correctly while raising and lowering and stayed solid while it was up. However, when I installed the 996 cluster I lost the flashing while raising and lowering. It stays on solid while it is up and can still operate the spoiler manually. Based on what a PIA the wires are to deal with I have left it as is. The flashing lights were not that big of a deal. Having the solid light on is more important to me.
You do have an issue if the blinkers are causing the indicator to flash. I would betting a wire is plugged into the wrong slot of the plug.
1995 Porsche C4 Cab
11-27-2015, 07:26 AM
Probably will be OK. Would you help me out when you do the installation ? After inserting the wires into the gauge cluster blocks, raise or lower the the spoiler and determine which wire transmits the flashing. Then I'll know which one of mine is in the wrong slot.
11-27-2015, 09:03 PM
It will be a while before I can get to it.....spring as the car is all stored up. Not sure you would want to wait that long! It sounds like a real pain and am dreading it! Are the instructions wrong such that you cannot determine the right terminals?
The dude sent me an old crusty switch...which I have been trying to get replaced...no luck so far. I believe it is a just defroster switch with a sticker on it
986 00S
04-20-2014, 05:17 PM
I installed mine last week as per the instructions and it was a simple install. It works great.
05-01-2014, 05:40 PM
Having some mysterious alignment trouble with my spoiler...this switch would help! I actuate it up manually but it retracts on its own somehow..
986 00S
05-02-2014, 03:19 PM
I installed the spoiler switch in my 2004 eight years ago. As you see in the photo below, my switch doesn't have an indicator light, just an icon on one side of the button showing the spoiler raised, and one on the other side showing it lowered. Works like a charm and was very easy to install.
05-02-2014, 03:34 PM
You have no indication if it is up or down?
05-02-2014, 04:24 PM
Nope, which is why I had my wife drive behind me one day to verify that the spoiler does, in fact, raise on its own when I reach a certain speed. I have used the switch to raise the spoiler manually, but if I am going too slowly it eventually lowers on its own.
Mostly I just use the switch to raise the spoiler when I am cleaning the car.
12-13-2014, 07:21 AM
I raise mine manually on occasion, sometimes it's still up when I finish my drive, and sometimes it has lowered on its own. I think it has something to do with the speed of the drive but I am not sure what. Maybe if you surpass 75 on the drive it will then lower at 55.
12-13-2014, 02:26 PM
There Is No Substitute.
It goes up at 75mph, and goes down at 50mph. I installed the a dash switch, but rarely use it. It's mostly for showing off, or if I have someone following me. It's hard to miss the giant red, 'PORSCHE,' logo on my spoiler.
Also, a note on the install, the little wires you insert into the instrument cluster plug are very fragile, be careful not to bend one.
12-13-2014, 03:57 PM
It'so not wired directly to the footwell switch ? Curious
