Originally Posted by mountainman
Did you have any problems getting yours to make contact and do you have any tips. After several tries and no success on the boxster I just gave up and have not tried the 996 yet. I suppose I could splice into the appropriate wires back behind the dash connectors, but I really do not want to do that. It just appears to me that the small flat blades on the wire ends are about 1/4 inch too short to make contact.
Even though the install is straight forward, it was challenging. I had no success my first attempt and tried to tap into the wires as they left the connector, but for some reason this did not work either. By the time I was done with my first attempts I had broken off two of the tips from the wires. I sent the unit back to Germany and the seller sent me a new one. This time I took my time and straighten out all of the wires in the connector (they make a 90 degree turn as they come out of the connector). I installed the green wires first as they are the most difficult. The other three are pretty easy. They simply slide in on the outside portion of the connector.
I think the key is the straighten out of the wires so you can see what your doing and taking your time.
1995 Porsche C4 Cab
