Old 12-19-2012, 10:05 AM   #1
Heiko's Avatar
Meir I think these are both the same (check the details to see if one comes with extra parts) it must for the extra $$$...
The first one is good for 05-06 987S and 07-08 987 non-S, the second for 07-08 987-S I would think you will need the first one (now i'm confused) LOL
As far as I understood the 987S clutch will fit the 986S and the stock 987 clutch will fit the 986 (non-s) - but I didnt realize there was two different 987-S
clutches 05-06 and 07-08. I think the friction material is a bit different and the spring might be a bit stiffer. Personally i would just go with the 986S Sachs
clutch it hasnt let me down yet and lasts just fine.
Previously owned:
Old 12-19-2012, 10:11 AM   #2
1999 base
Meir's Avatar
Originally Posted by Heiko View Post
Meir I think these are both the same (check the details to see if one comes with extra parts) it must for the extra $$$... As far as I understood the 987S clutch will fit the 986S and the stock 987 clutch will fit the 986 (non-s). I think the friction material is a bit different and the spring might be a bit stiffer. Personally i would just go with the 986S Sachs clutch it hasnt let me down yet and lasts just fine.
thanks Heiko.
from a quick search i did, i read some posts that say the 987 clutch is a bit softer (but again, a new clutch will be always softer then the old one).
i now noticed that the pic is not that clear.
the first one (710$) is part # 987-116-913-23-M38
the second (441$) is part # 987-116-913-32-M38
