Old 12-01-2012, 10:09 PM   #1
clutch switch to start engine?
Is there a switch that goes bad on the clutch? It seems I'm having a hard time starting my engine where it won't even start or turn over unless I press the clutch very hard.
ohhh my is offline   Reply With Quote
Old 12-01-2012, 10:32 PM   #2
Redacted/removed.
Old 12-02-2012, 03:22 AM   #3
Ex Esso kid
The switch comes apart and can be serviced if you're careful and into dis assembly of a small part. I had to do the brake switch every other year.
PS 986 needs to grant limited mod powers to delete threads to multiple members before Poland turns this awesome site into a reading test.
Old 12-02-2012, 04:49 AM   #4
1999 base
Meir's Avatar
The clutch switch is located on the clutch pedal under the dash. It looks a lot like the brake light switch on the brake pedal. It goes bad easily and will stop the car from starting (because the clutch needs to be depressed to start the engine). Cheap and easy to replace.
This is not correct (sorry).
The switch that looks like brake switch, is used to deactivate the cruise control when pressing the clutch lever.
Ther is another switch located right next to it. It has a metal arm that can be adjusted by bending it. That wil make the clutch lever touch the switch sooner.
Old 12-07-2012, 04:00 PM   #5
Boxster S Bassist
Just bypass it by jumpering around it, that is what my mech recommended and did. Then remember not to start the car in gear!
John Bergen is offline   Reply With Quote
Old 12-07-2012, 04:15 PM   #6
And just remeber that doing so will cause the car to fail state inspection in some areas as you are defeating a Federally mandated safty device. Many shops will also not do this as it opens up the possiblity for a liability claim down the road...........
Old 12-07-2012, 04:23 PM   #7
golonaus's Avatar
You can reprogram your ECU to euro spec. No clutch at startup
That's what I did
