Old 09-29-2005, 12:21 AM   #1
Unhappy Ignition problems!!
I can't start my 97 Boxster's engine every time. I can turn the key no problem and the engine crank every time but just couldn't start sometime. Sometime I have to try 3-4 times in order to get the engine start. I thought my engine was cold at the begining, but sometime it happens 30 minutes after I turn off the engine. Weather is still hot here in Los Angeles. Is my battery bad? The Battery warning light was not on. Is it the starter or ignition problem? It worries me, coz I just bought this Box for just a week.... Anyone has such problem before? Thanks.
97Boxsterian is offline   Reply With Quote
Old 09-29-2005, 05:36 AM   #2
pez
Send a message via AIM to pez Send a message via Yahoo to pez
Does the key stick when you try to remove it?
If so it could be the start of the ignition switch going south.
When they act up you can get all kinds of flaky problems, everything from not being able to insert/remove the key, radio not working, blowermotor not working, key getting stuck in the start position ect.
Check out Renntech as it’s a known problem and somewhat easy to fix, IF it is the switch.
Pez
pez is offline   Reply With Quote
Old 09-29-2005, 05:41 AM   #3
I think what you're really describing is Hard Starting, that is, the car starts, but only after several attemps am I right?
Hard starting can come from a variety of issues. There just isn't one simple answer here. Hard Starting can often be the result of a combination of issues.
Fuel/Air/Spark - these are the three basic requirements for an engine to run. Let's look at each:
Fuel
a.) Fuel Pump - do you hear it running with the Ignition ON, but before engaging the Starter? Does it sound slow, labored? The Fuel Pump is an electrical device which has fuses and relay(s). The Fuse is most likely good, as the car does eventually start, but the Relay may be sticking sometimes. No good way to easily test a relay, usually swapping it with one known to be good is the best test here.
b.) Fuel Filter - Is it the original? A partially clogged Fuel Filter can make starting the car more difficult as the Fuel Pump is operating just on Battery power until it starts and this can be insufficient for a Pump to work through a clogged or partially clogged Filter.
c.) Clogged or partially clogged injectors can make a car hard to start. There are a number of products out there designed to remove the varnish which your fuel deposits on the injectors. You add these to your Fuel Tank when you fill-up. Try this for a couple tankfuls.
Air
a.) Air Filter, check it to see that it is still servicable and not clogged. Here again, at starter cranking speeds, air is harder to pull through a clogged Air Filter. Remove it and hold it to the light. If visible dirt can be seen, replace it. If a K&N type Filter, replace it with a standard Filter - the K&Ns will clog in 1/3 the time of a standard Filter.
b.) Vacuum Leaks - check all vacuum hoses to make sure they're connected and in good shape. Loose or cracked vacuum hoses will reduce the engine's ability (in some cases) to draw air in, especially at Starter speeds.
c.) MAF Sensor This sensor regulates the amount of fuel injected into the engine by sensing the amount of Air being drawn in. Without an OBD Reader, it's difficult to test it's operation, but if everything else checks out, this could be the culprit. The use of K&N type filters have been known to give the MAF sensors a hard time as the oil in these Filters can contaminate the sensor. If you have one of these Filters, I'd replace it with a standard papper one.
Spark
a.) Battery - The most obvious thing. If it is weak, it is more difficult to start the car. Using a Multimeter, set to DC scale, test the Voltage by touching the Tester Leads to each terminal of the Battery (Car OFF). You want to see a minimum of 12 Volts, 12.5-13.0 Volts would be better. If in doubt, replace the Battery, it may be the Original one and is simply wearing out. Also, check for condition of Battery Cables. Make sure they are not worn, cracked or loose.
b.) Alternator - This is what keeps your Battery fully charged. Check the Accessory Belt (Polyrib Belt) to insure that it is tight enough. Also, with the car running and using the Multitester, check the Alternator's Output as described in my thread about Alternator Testing in the Technical Section here. Correct as necessary.
c.) Spark Plug cables - Inspect these to insure they are not loose or cracked. Replace or tighten as required.
d.) Spark Plugs - Check these to insure that they are in good order, not cracked or fouled. If in doubt, replace them. These are currently on sale at: http://shop.store.yahoo.com/eagleday/993bilovaco.html . Since your car is older, you don't know how long they've been in service, best to replace them and start from a fresh baseline.
If these things do not solve the problem, there are any number of other possible causes which would be impossible to list here.
But, since your car is older, it's probably time to start replacing some of the components I've listed above anyway (unless you have a full Service History indicating that some/all of these things have been addressed) and I suspect that this is most likely to solve your issues. If not, at least you will have eliminated them as possible causes. Hope this helps...
Happy Motoring!... Jim'99
Old 09-29-2005, 10:38 AM   #4
Arrow
Thank you guys! Since the hard starting problem might be caused by different things like air filter, sparks, fuel and air...etc. I think it is time to service my Boxster coz it has 35k miles on it and the last owner didn't get 30k service. Hope the hard start problem will go away after I finish the 30k miles service. Agree?
Old 09-29-2005, 11:27 AM   #5
deliriousga's Avatar
Definitely get the 30K service done. New plugs & filters can do wonders. Don't forget the cabin filter for the A/C system.
If any of the plug wires are cracked, they are sold separately because they have a coil on the head of each one. They are around $55 each online.
If you order the plugs listed above, be patient. I ordered some and it was two weeks before they were shipped. Great price, but not a good place to go if you're in a hurry.
1966 Wife White/Brown Top
Old 09-29-2005, 12:51 PM   #6
Arrow
My Boxster has RMS leaking too, I want to get it fix in dealer since warranty cover that. But I don't want to do the 30K service in dealer coz it costs $850. Do u think I should get the 30K service frist or fix the RMS leaking first? Is my ignition problem more important than RMS leaking problem? I can't do both at the same time coz I want to do it in different place. By the way, anyone know good mechanic in Los Angeles area who can do the 30K service cheap? Thanks.
Old 09-29-2005, 05:29 PM   #7
You can DIY the 30k service for about $150. It's just a plug, air filter, cabin filter & oil change and top lubrication. It took me about 2 hours to do it. The plugs are directly behind the rear wheels so they're easily accessed.
If you're going to pay a mechanic for something, make it the RMS.
Old 09-29-2005, 06:03 PM   #8
HI,
Sound advice...
Happy Motoring!...Jim'99
Old 10-05-2005, 02:45 PM   #9
Thank you all!!! I finished the 30K service today, and the hard starting problem is gone.
Old 10-05-2005, 04:26 PM   #10
That's Great! I'm sure that one or more of the replaced components was causing your Hard Starting. BTW, thanks for reporting back, many who seek advice don't, leaving us with no idea whether we were able to help or not.
Old 10-05-2005, 10:56 PM   #11
I appreciate you guys help a lot!!! I mean it so I definately will keep you guys updated! I didn't DIY this time, coz I am afraid I screw it up. I paid $670 for 30K service, brake flush and fluid change to a local mechanic here. I am not a hand on person but I am interest to learn. You guys said it is easy to do DIY this service. I hope I can learn it and do it myself next time. What kind of tools we need for this kind of service? Where can I buy the spark plugs and all kind of filters and other supplies?
Old 10-06-2005, 12:08 AM   #12
Wow $670 would definately have covered the cost of all required tools for this job. You would need to start w/ a basic metric socket set , metric allen wrenches, filter wrench, oil drain pan(at least 9quart), jack stands, and maybe a small hydrolic jack. Get the tools and start w/ small projects to build confidence and familiarity. There are plenty of online resources for projects and instruction. You'll get much satisfaction from doing these things yourself.
1999 Arctic Silver Metallic/Graphite Grey top/ tiptronic transmission
nautiquelfe is offline   Reply With Quote
Old 11-04-2005, 12:15 AM   #13
Unhappy
After having great time with my 97 Boxster for about 1 month, the hard starting problem comes back I bought my baby to Porsche dealer yesterday and they call me today telling me the Mass Air Flow Sensor is bad. It will cost me $500 for part and $300 for labor. Do you think I can replace the sensor myself? Should I try replace the filter first and see if it fix the problem? Please help!
Old 11-04-2005, 06:08 AM   #14
Brucelee's Avatar
Thanks to all that provided advice here. Happy outcome and he saved money!
Nice job!
Old 11-04-2005, 07:46 AM   #15
pez
Yup, I'm in the same boat as you , you can try getting a T-20 anti-tamper torx and some electrical contact cleaner and clean the business end of the MAF some people have had luck with that. I have not had a chance to get to mine yet.
You are lucky the MAF you have in your box is the older design and you should be able to replace it yourself fairly easily. (the newer version MAF requires it to be programmed into the ECU $$)
For replacing the filter first? I’m assuming you mean the Air filter, do you have an oiled filter like a K&N on there? Has the Check engine light come on? (if so you should try to get a OBD-2 reader and get the codes). If the check engine light is on the MAF is already hosed and changing the filter will not change the symptom.
Do a search on http://www.renntech.org/ I was going to post a link to a thread there but the site is currently being updated and is down for a bit.
Pez
Old 11-05-2005, 09:39 PM   #16
Pez
Thank you for the advice! My engine light is not on, so I guess I will try cleaning the MAF sense frist and see how it turns out. What is T-20 anti-tamper torx? Can I buy it in local auto accessory store like pepboys, autozone...etc.? Which kind of electrical contact cleaner would you recommend? I found lots of tread in renntech.org about MAF, I guess we don't need to be worried. I will try cleaning it next weekend and I will update you. Thank you
Old 11-07-2005, 07:34 AM   #17
The T-20 anti-tamper (aka security) torx is a torx wrench with a hole in the middle of it. The screw holding the MAF in has a small peg in the middle of the torx hole to keep you from being able to work on it yourself. They are available at most auto parts stores and easy to find online if nobody local carries it.
For electronics cleaner, I'd just go to Radio Shack and get some. I have a hard time finding it at auto shops.
Good luck!
