Does the key stick when you try to remove it?
If so it could be the start of the ignition switch going south.
When they act up you can get all kinds of flaky problems, everything from not being able to insert/remove the key, radio not working, blowermotor not working, key getting stuck in the start position ect.
Check out Renntech as it’s a known problem and somewhat easy to fix, IF it is the switch.
Pez
