Old 10-28-2012, 08:03 AM   #1
Hole in door frame
I hope someone can tell me why someone would drill a hole in the door frame of a Boxster. See attached photo.
opus69 is offline   Reply With Quote
Old 10-28-2012, 08:19 AM   #2
Possibly paintless dent repair. They usually put a little rubber plug when they drill a hole to access a dent.
Botoxster is offline   Reply With Quote
Old 10-28-2012, 08:21 AM   #3
I had to run out & see if my car had that hole!! I would have freaked if I had missed that all this time
Bryan topping is offline   Reply With Quote
Old 10-28-2012, 11:57 AM   #4
Heiko's Avatar
The Rustproofing people drill holes that size into vehicles and put rubber plugs in as well (ironically enough they all rust where the holes were drilled first...) why would anyone do that to their car!!!
Previously owned:
Old 10-28-2012, 12:07 PM   #5
Originally Posted by botoxster View Post
possibly paintless dent repair. They usually put a little rubber plug when they drill a hole to access a dent.
+1 ........
seventythree is offline   Reply With Quote
Old 10-28-2012, 12:08 PM   #6
srad34's Avatar
Why would you do that? The body is galvanized?
It will all end in tears I tell you.......
srad34 is offline   Reply With Quote
Old 10-28-2012, 03:07 PM   #7
Spinnaker's Avatar
Bullet hole left over from mission with JDanger.
Old 10-28-2012, 03:53 PM   #8
dan.oneufer's Avatar
Passenger door? Odd, I have that identical hole in the exact same place on my driver side door frame. I always just assumed it was just a paint-less dent repair, but maybe there is something else going on...
2003 Boxster S Dark Teal
dan.oneufer is offline   Reply With Quote
Old 10-28-2012, 05:20 PM   #9
Heiko's Avatar
Srad34 - Up in our neck of the woods, some folks seem to believe in taking their car to rustguard shops to get them rust protected due to the amount of salt the highway crews dump on our roads in the winter time. Not really sure either why anyone would want to drill holes in their car but then i'm not sure why anyone would drive a car like this in the winter either! Could be a PDR hole but I know you can get to this area via other methods to get the dent repair tools into... Probably best to put a few dabs of expoxy primer along the hole edge to cover all the exposed metal and pop a rubber plug in the hole.
Previously owned:
Old 10-29-2012, 06:24 AM   #10
The car was always in Texas before I bought it. Not likely to be rust proofing since one side only. If it was a dent repair it worked quite well, but there was no record of this type of repair.
Old 10-29-2012, 07:44 AM   #11
Heiko's Avatar
The paintless dent repair if done right is actually quite good. I had a rear fender done a few years ago and the guy took the tail light out for access and you couldnt tell when he was done - pretty awsome. Not cheap mind you, but certainly a better option than giving up the original painjob :-) I had just not heard of them drilling holes... and why wouldnt they cover them or at least fill them... 'like lets fix a dent but make a hole' LMAO
Previously owned:
Old 10-29-2012, 07:59 AM   #12
BYprodriver's Avatar
Smuggling drugs or illegal aliens.
Old 10-29-2012, 04:51 PM   #13
If they were transporting illegal aliens in that hole they would have to have gotten them fresh from the cojones, and put them in with an eye dropper.
Old 10-29-2012, 05:28 PM   #14
... but there was no record of this type of repair.
CarFax, etc are notorious for their lack of full and complete repair data.
