Old 09-13-2012, 01:46 PM   #1
What do you use to clean the exhaust pipe chrome ??
Mine is almost dark brown in coloar and I want to bring back the silver color.
Thanks in advance for your insight.
SvenskaPoika is offline   Reply With Quote
Old 09-13-2012, 01:48 PM   #2
Ex Esso kid
This stuff is the best but a cleaning wax will do
Shoe Polish - Simichrome Polish 1oz
Old 09-13-2012, 02:45 PM   #3
Brasso, Autosol metal polish, and a lot of 'hand' power
rene525d is offline   Reply With Quote
Old 09-13-2012, 04:03 PM   #4
Old 09-13-2012, 04:22 PM   #5
I have to agree with rene525d...autosol is hands down the best polish Ive come across!
58ceramicgreen is offline   Reply With Quote
Old 09-13-2012, 05:56 PM   #6
Skrapmot's Avatar
Flitz. Buy it at Ace Hardware.
Old 09-13-2012, 07:10 PM   #7
Jaak's Avatar
Never-Dull in blue can.
2002 Boxster S Seal Grey
2010 Ford F150 FX4 Luxury
Retired after 38 years with the same company.
Jaak is offline   Reply With Quote
Old 09-13-2012, 07:39 PM   #8
Solvol Autosol is amazing. I used to use it to take the blue off my bike pipes. I've just started using Never-Dull and I have to say I'm pretty impressed so far.
If your exhaust tip is removable then nothing will beat a buffing wheel with proper polishing compound.
'99 black 986
Old 09-14-2012, 05:28 AM   #9
Homeboy981
Homeboy981's Avatar
I have chrome rims and the Mfr. told me on no uncertain terms that the ONLY thing they recommend is NEVER-DULL (or similar chrome polish).
The Mfr. said to stay away from the waxes and "other polishes", because, while they work for a time, eventually they will strip the outer layer off of the chrome (not sure what the chemical is called), it is the thinnest layer of the whole process. So you have to treat it delicately.
After paying a premium for the rims, I have taken their advice. It is tough on rims since they attract braked dust like a magnet!
Never-Dull does have some repellent properties and seems to shed the dust for about 2 weeks. No problemo since I wash the car AT LEAST that often.
Someone mentioned "elbow grease"….it takes a lot of that and for the pipes - you are going to have Porsche Elbow! No Pain, No Gain!
Hope this helps.
Old 09-14-2012, 07:31 AM   #10
jb92563's Avatar
Hope this helps.
HomeBoy, are you sure your rims are chrome plated steel? Somehow I doubt that, as they are probably polished Aluminum. Look for polished aluminum products on those. I guess if you follow manufacturer advise on the rims it should be fine.
Chrome plated steel exhaust tips are different material, harder, and can take a good polishing with abrasive compounds now and then but because it is a thin plating you don't want to use the abrasives too often on them as you'll wear down to the steel eventually.
Old 09-14-2012, 07:34 AM   #11
SolidWorks Mike is offline   Reply With Quote
Old 09-14-2012, 07:40 AM   #12
Hope this helps.
If the rims are triple plated (like most high quality chrome should be), the first layer will be copper, then nickel, then chrome. The only other layer might be a clear coat which would chip and scratch. Chrome is a hard material and can withstand quite a bit.
On my H2 Hummer I clean all the chrome stuff with spot free glass cleaner. It has vinegar in it which removes water spots. Thats it, no need for anything else.
If you want to try to keep brake dust from sticking on them, you might want to give them a coat of car wax, that will make them a little bit smoother and the dust wont have as many areas to stick to.
