Old 08-03-2012, 02:50 PM   #1
Oil filter only change
It is possible to change only the oil filter WITHOUT changing the oil?
I realize that I need to top off once I change the filter.
I want to inspect the filter between the oil changes.
How much oil can/will come out just changing the filter?
Thanks in advance.
mikehkang is offline   Reply With Quote
Old 08-03-2012, 03:27 PM   #2
boxster6354's Avatar
Hey
i had to do it a bit back on a 2000MY and I loss maybe a quart or less, just make sure to have a good container underneath to catch the oil.
Old 08-03-2012, 03:37 PM   #3
Thanks in advance.
Yes. I did it a few weeks ago after a track day. You will lose around .5 quart of oil.
Boxster586 is offline   Reply With Quote
Old 08-03-2012, 05:24 PM   #4
The oil filter is mounted higher than the oil sump so you won't have all 10 qts pouring out when you remove the filter/holder. You'll only lose what is in the oil filter itself and the line directly above. A bit messy but easy. Just be sure to top up the oil after installing the new filter.
Old 08-03-2012, 05:44 PM   #5
thstone
Boxster586
boxster6354
Thank you guys.
You guys are awesome!
Old 08-03-2012, 08:44 PM   #6
kls
I did that very thing this week. I check it at about 2,500 miles and change the oil at 5k. I have the LN oil filter adapter so it's a bit more of a pain, but this makes quick work of the filter;
Amazon.com: Oil Filter Cutter: Automotive
kls is offline   Reply With Quote
Old 08-04-2012, 04:12 PM   #7
husker boxster's Avatar
Removing the filter is how us 987 guys alleviate an oil overfill. (We don't have a dipstick.)
1989 928 S4 5 spd - black
Old 08-04-2012, 06:35 PM   #8
So Mike, what did you find in your filter?
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 08-04-2012, 08:18 PM   #9
As long as you're within +/- 0.5 quart you're still okay...? Hard to see how someone can overfill it... if it takes 9 quart put in say 8 3/4 qt since there'll be oil after draining the oil pan...?
The 986 dip stick is not exactly easy to read compare to say one from Toyota. I use the electric gauge and don't check the dip stick after an oil change.
Old 08-05-2012, 03:17 PM   #10
You are sharp!!
I found flexible/rubbery green bits in the filter.
From searching this forum, I am concluding that they are sealant.
Old 08-05-2012, 10:29 PM   #11
Topless's Avatar
Actually oil overfill is a lot more common than you might think and it's the fastest way to kill your AOS. Some of the reasons:
1. Not getting the car level when draining.
2. Not allowing enough time for a complete drain.
3. Not measuring refill carefully.
I always refill with 8.5qts at first and drive the car a bit. Re-check and top off when the car is level and the gauge countdown has timed out.
Old 08-06-2012, 12:32 PM   #12
FWIW my 987 only takes 8 quarts with an oil & filter change. Putting in 8.5 or 9 quarts is how you get an over-full condition
Old 08-06-2012, 02:38 PM   #13
Opposed to Subie Burble
Overdrive's Avatar
Did the capacity change with the 987? I can't remember the exact figure in my manual, but for my 97 it says the capacity is 8.9xx or 8.7xx quarts, something like that. I just remember that it was a very high 8, not quite 9 quart capacity.
I swear though, I look at this car sometimes and wonder just where it puts all that oil compared to the Corolla with its seemingly meager 4 quarts.
-O/D
IMSR + RMS
Robbins glass window top
