Old 08-05-2012, 09:29 PM   #11
Topless
Track rat
Topless's Avatar
Originally Posted by ekam View Post
As long as you're within +/- 0.5 quart you're still okay...? Hard to see how someone can overfill it... if it takes 9 quart put in say 8 3/4 qt since there'll be oil after draining the oil pan...?
Actually oil overfill is a lot more common than you might think and it's the fastest way to kill your AOS. Some of the reasons:
1. Not getting the car level when draining.
2. Not allowing enough time for a complete drain.
3. Not measuring refill carefully.
I always refill with 8.5qts at first and drive the car a bit. Re-check and top off when the car is level and the gauge countdown has timed out.
