Old 07-04-2012, 03:47 AM   #1
Water drip pan 986 (under hood)
Hi All
Does anyone know where I can get the foam tray (pasenger side) insert- allows water to drain away from the car -instead of into the pasenger side inside the car on a 986 (1999) Boxster ??
If you lift the hood down half way on the converible boxster you can see these drain trays.
This car has cost me a bonb in the 5 months ive had it....now ive gained a leak with a hole in this foam water drain pan thing.
Thanks all.
Paul
Pauleyj is offline   Reply With Quote
Old 07-04-2012, 05:24 PM   #2
You need PN 986-561-806-03 (right/passenger side), Item #12 in the diagram below.
Can be ordered from Auto Atlanta here:Porsche Boxster Roll-over Bar Parts. You also might want to check pricing at SunCoast or a few other good online OEM parts sellers.
Old 07-09-2012, 11:23 AM   #3
Thank you
Thank you very much ive got one now
Anyone know how to get the hood off so I can fit it ???
Paul
