Old 07-04-2012, 03:47 AM   #1
Pauleyj
Water drip pan 986 (under hood)
Hi All
Does anyone know where I can get the foam tray (pasenger side) insert- allows water to drain away from the car -instead of into the pasenger side inside the car on a 986 (1999) Boxster ??
If you lift the hood down half way on the converible boxster you can see these drain trays.
This car has cost me a bonb in the 5 months ive had it....now ive gained a leak with a hole in this foam water drain pan thing.
Thanks all.
Paul
Pauleyj is offline   Reply With Quote
