-   -   Water drip pan 986 (under hood) (http://986forum.com/forums/boxster-general-discussions/36196-water-drip-pan-986-under-hood.html)
Pauleyj 07-04-2012 03:47 AM
Hi All
Does anyone know where I can get the foam tray (pasenger side) insert- allows water to drain away from the car -instead of into the pasenger side inside the car on a 986 (1999) Boxster ??
If you lift the hood down half way on the converible boxster you can see these drain trays.
This car has cost me a bonb in the 5 months ive had it....now ive gained a leak with a hole in this foam water drain pan thing.
Thanks all.
Paul
thstone 07-04-2012 05:24 PM
You need PN 986-561-806-03 (right/passenger side), Item #12 in the diagram below.
Can be ordered from Auto Atlanta here:Porsche Boxster Roll-over Bar Parts. You also might want to check pricing at SunCoast or a few other good online OEM parts sellers.
http://i1114.photobucket.com/albums/...TopDripPan.jpg
Pauleyj 07-09-2012 11:23 AM
Thank you
Thank you very much ive got one now :)
Anyone know how to get the hood off so I can fit it ???
Paul
