Old 07-02-2012, 08:48 PM   #1
Eibach vs H&R lowering springs
What are the pros and cons between the two? I will be using the stock shocks in the meantime. The car will be used on the street and so am looking for the smoother ride and more forgiving spring rates.
3point2 is offline   Reply With Quote
Old 07-03-2012, 04:43 AM   #2
Johnny Danger's Avatar
Similar quality between the two . Both incorporate a stiffer/progressive spring rate over the oem set-up . Therefore, ride quality is subjective. Note of caution, however, while others may disagree, the change in spring rate may over time take it's toll on the oem struts.
Old 07-03-2012, 06:51 AM   #3
Thanks for the reply Johnny.
Do you know if there's a difference between the boxster and boxster s suspensions? I've heard that the s is actually 0.5 inch lower in ride height.
Old 07-03-2012, 06:52 AM   #4
ppbon's Avatar
Eibach...
... has discontinued it's Pro series for the Boxster, so you'd have to go with a used set.
Both of the sets (Eibach and H&R) are geared for performance hence, they will be much firmer than the OEM.
If you're looking for a smooth ride, stay with the original springs.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
Old 07-03-2012, 07:54 AM   #5
Track rat
Topless's Avatar
Personal preference:
Not a fan of lowering springs on a Boxster. The best way to lower the car is with adjustable coilovers. Handling and bump-steer often get ugly with lowering springs only.
YMMV
Old 07-03-2012, 08:28 AM   #6
Recently installed Eibach Springs. 1 inch lower.
I felt no difference in ride quality. Feels exactly the same to me. I might have felt a slight difference when going over bumps. But barely any difference.
00 2.7 5SPD MT
ProjectM96 is offline   Reply With Quote
