Old 07-03-2012, 06:52 AM   #4
ppbon
ppbon's Avatar
Eibach...
Originally Posted by 3point2 View Post
What are the pros and cons between the two? I will be using the stock shocks in the meantime. The car will be used on the street and so am looking for the smoother ride and more forgiving spring rates.
... has discontinued it's Pro series for the Boxster, so you'd have to go with a used set.
Both of the sets (Eibach and H&R) are geared for performance hence, they will be much firmer than the OEM.
If you're looking for a smooth ride, stay with the original springs.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
