Old 07-03-2012, 04:43 AM   #2
Johnny Danger
Johnny Danger's Avatar
Originally Posted by 3point2 View Post
What are the pros and cons between the two? I will be using the stock shocks in the meantime. The car will be used on the street and so am looking for the smoother ride and more forgiving spring rates.
Similar quality between the two . Both incorporate a stiffer/progressive spring rate over the oem set-up . Therefore, ride quality is subjective. Note of caution, however, while others may disagree, the change in spring rate may over time take it's toll on the oem struts.
