Old 06-21-2012, 04:34 PM   #1
So first my boxster is 2001,
and i don't live in the US,
I thought maybe to buy a key from the US and sync it here in a local dealership,
because they charge you 350$ for a key than another 200$ for sync and cutting the blade!!
so i cant avoid the 200$ but maybe i can buy the key for less from ebay or something....
thank you shadrach74 for the links ... i checked it ... it will cost me 160$ +-
then i can save 200$ +-
but before i buy it , there is something i need to check before ??
i know there was car keys with 1,2 or 3 buttons... is there more difference that i don't know about?
or it 100% fit to my car?
and is it open also the two trunks?
thanks you all!
Eli
eliimports is offline   Reply With Quote
Old 06-21-2012, 05:42 PM   #2
My S is an 02 and I bought the 3 button. As long as you have electronic trunk release buttons and not the earlier style mechanical levers they should be able to program the 3 button. My car originally came with a 2 button. Also check the key you're currently using the transmitter frequency should be written in small print on the plastic housing; it should be 315Mhz.
thanks you all!
Eli
shadrach74 is offline   Reply With Quote
Old 06-22-2012, 03:04 AM   #3
this is what written on the remote:
delphi
type txf 433p4
n11042
did it mean anything?
Old 06-22-2012, 05:01 AM   #4
The key for my 02 S reads as follows:
Delphi TXF315P3
CAN 3659104467
LTQTXF315P3
FM - 315 MHz
You might call the dealer and tell them you have a key with those numbers and ask them if it will work.
From what I'm reading it looks like you have a different PN# (and FM freq) than I do. That does not mean it's the right PN#. It's possible taht the guts were switched out. Ask your dealer what you need and verify with the seller before you buy.
