Old 06-21-2012, 05:42 PM   #2
shadrach74
My S is an 02 and I bought the 3 button. As long as you have electronic trunk release buttons and not the earlier style mechanical levers they should be able to program the 3 button. My car originally came with a 2 button. Also check the key you're currently using the transmitter frequency should be written in small print on the plastic housing; it should be 315Mhz.
Originally Posted by eliimports View Post
So first my boxster is 2001,
and i don't live in the US,
I thought maybe to buy a key from the US and sync it here in a local dealership,
because they charge you 350$ for a key than another 200$ for sync and cutting the blade!!
so i cant avoid the 200$ but maybe i can buy the key for less from ebay or something....
thank you shadrach74 for the links ... i checked it ... it will cost me 160$ +-
then i can save 200$ +-
but before i buy it , there is something i need to check before ??
i know there was car keys with 1,2 or 3 buttons... is there more difference that i don't know about?
or it 100% fit to my car?
and is it open also the two trunks?
thanks you all!
Eli
shadrach74 is offline   Reply With Quote
