Old 05-19-2012, 08:56 AM   #1
DIY extremist
black_box's Avatar
Exhaust sound comparison - "Charlie Chan" vs. Modding Stock Muffler
Planning to install Topspeed secondary bypasses next month when the new shipment comes in, and simultaneously free up the muffler sound too. Trying to decide between cutting and welding the stock 986 S muffler or going with the cheap "Charlie Chan" style mufflers.
An ideal exhaust sound for me would be a noticeable, but not annoying burble at idle, with a throaty midrange and a howl at high RPMs. I do not want to set off car alarms on city streets just driving though.
Can owners of either of these setups post links to high quality recordings of the sound they produce? Also, any comment about the resonance "drone" produced would be helpful.
Car is a stock (other than desnork) 2000 S model.
Thanks guys!
black_box is offline   Reply With Quote
Old 05-19-2012, 10:28 AM   #2
those mufflers are not very loud....and you will gain a significant weight savings ditching the stock one
fivepointnine is offline   Reply With Quote
Old 05-19-2012, 10:43 AM   #3
Perfectlap's Avatar
Something about putting anything referred to as Charile Chan on a Porsche just seems wrong. Like putting 24 inch "spinners" on a Range Rover.
Old 05-19-2012, 11:03 AM   #4
jacabean's Avatar
don't knock the charlie chan cans because you could pay a lot more and get the same thing. chan muffler and delete pipes are a great combo and value .
Old 05-19-2012, 11:05 AM   #5
Moderator
The muffler serves a purpose- performance. Thirty pounds of weight savings, and reported 10hp increase at higher rpms. As for spinners... Aesthetics. Higher diameter wheels are counterproductive, wasting gas and reducing speed. I think these mufflers are a great alternative to a $1200 muffler.
Old 05-19-2012, 11:29 AM   #6
DIY extremist
black_box's Avatar
Ah.... the "Porsche Tax".
Any car can be done right or wrong and a lot of the time it's not very well related to how much you spend.
I respectfully disagree with you PerfectLap (also, I see we're neighbors, sort of!). Spinners are in my opinion, dangerous and gaudy, and I would not put them on any car. But that's not what we're talking about here. Junk is junk and doesn't belong on anything of mine.
There is no rule saying that everything I use on my Porsche has to cost 2x-3x what a comparable item for "normal" cars costs. If an item is of sufficient quality and it looks like it will work for my application, I'll use it after careful research. I've also found that, while sometimes quality and price are correlated, that the dealers and aftermarket for these cars rely on the notion that because the cars were expensive that every part for them must also be, regardless of its actual to cost produce or quality. Quite a business model, if you can make it work.
I'd prefer to evaluate on a case-by-case basis... and from what I've read the build quality on these mufflers, generically referred to on this board as "Charlie Chans" is decent, certainly good enough for a part that cannot cause the car to suffer any catastrophe should it break and is only being installed to increase the volume on my teutonic hairdryer.
I know that, sometimes, it is good to play the money-is-no-object game, but in this case I'd rather keep in my pocket the thousand$ people spend on exhaust, and rather save towards my next Porsche.
Don't even get me started on the inflated labor rates for very routine work, $150 oil changes and such...
Old 05-19-2012, 12:20 PM   #7
Opposed to Subie Burble
Overdrive's Avatar
Not necessarily so cut & dry. Though they'd cost significantly more, if you buy a larger wheel that is the same weight or lighter, you're not hampering performance or efficiency in that way, and so long as you can find a tire size that matches the overall diemsion of your tire + wheel package, the only potential weight difference that could exist is how much one tire weighs compared to the other.
Now when people go way oversized and can't help but be on heavier wheels and have a wheel and tire combination that creates a diameter larger than stock, then you get exactly what you're saying. This is unfortunately what happens since people either don't care, don't know, or don't want to spend the additional money it will cost to get something that keeps dimensions and weight the same.
-O/D
IMSR + RMS
Robbins glass window top
Old 05-19-2012, 12:52 PM   #8
Perfectlap's Avatar
My issue is more with the name choice. Isn't there a German word for cheap but functional? LOL Charlie Chan muffler sounds like the latest Hot Import Nights marketing campaign.
At any rate, I don't see exhaust upgrades as a worthwhile investment. Certainly not for 10 hp. And the weight savings is better spent at the wheels. If anything it seems like a cosmetic upgrade just like the spinners in that its done for non-performance reasons (sound). The OEM exhaust had quiet a bit of engineering put behind it, it delivers all the performance the car will need unless you plan to wring every split second out its laps. but I agree it is unfortunate that you have to pay premium in the event of a needed replacement. That's why I went aftermarket when it was time to replace the original. But if Porsches were cheap to buy an maintain everyone would have one.
Old 05-19-2012, 02:58 PM   #9
Ex Esso kid
I give +1 to black box, not only for this post but his honest offer to help someone save huge cash on maintenance, I tip my hat sir. The headers on my 986 were Chinese and I read all the blight about them, yet when they arrived they were everything advertised and more. I drove my 986 spiritedly and never had a problem with the headers or thought they would eventually cause a problem. As for exhaust upgrades being a waste, I loved mine it sounded awesome, no waste. Legends grow from some legitimate bad experiences, sometimes excellent quality parts are made by secondary providers. From here on out for me, all parts will be factory stock.
PS I think OD is right about sizes, my 19" wheels don't seem to be slowing me down. In fact if there's anything frustrating about the spyder it's that any trip to near redline in any highway gear yields license revoking results. If you don't have a clean ramp for gear one and two forgeddabout it, hit three hard and it's far past legal by the time you upshift to four with two more gears in sport plus. Stay in it into fifth and I don't want to tell you what digits are displayed.
Old 05-19-2012, 04:14 PM   #10
Carnut
AndyA6's Avatar
To answer the OP question, I'm desnorked, secondary bypass pipes and drilled stock muffler (search in DIY section here).
I am very happy with the sound, no drone, not too loud but enough to get a few looks. Simple and effective.
'14 Boxster
Old 05-19-2012, 10:04 PM   #11
Johnny Danger's Avatar
From now on we should instead refer to it as the Benny Hanna exhaust .
Old 05-19-2012, 10:40 PM   #12
Idaho Red Rocket 3's Avatar
Talking
Yes. Japanese quality is much better than Chinese. But does a different name move production to Japan ?
2000 Boxster S
Old 05-20-2012, 06:54 AM   #13
DIY extremist
black_box's Avatar
I considered drilling the stock muffler as you did, and figured it can't hurt, but it seems like a big pain, because of my welded on tips.
I lifted the car a while back and tried getting a bit in there with no luck. It was the opposite of fun.
"Betty" -- 2000 Boxster S, Triple Black, loaded except PSM (sold to a good home)
"Veronica" -- 2008 Boxster S, Arctic Silver on Blue
"Maleficent" -- 2007 Cayman S, Red and Black, TPC Turbo 3.6L 460 RWHP, H&R RSS Coilover / TPC stage 2 suspension
Old 05-20-2012, 09:51 PM   #14
I'm planning on removing the chan cans on my exhaust and welding smaller tubing in their place.
:dance:
98 boxster
82 280sl parts for sale
feelyx is offline   Reply With Quote
Old 05-21-2012, 06:07 AM   #15
Here is the exhaust sound video I made for this exhaust. Skip to 2 minutes of the video to hear it.
Porsche Boxster 986 Cat-back Exhaust DIY - YouTube
00 2.7 5SPD MT
ProjectM96 is offline   Reply With Quote
Old 05-21-2012, 06:46 AM   #16
DIY extremist
black_box's Avatar
Thanks for the video ProjectM96! Great production too.
I have to say though, that the sound of dewolf's modded stock muffler does a lot more for me, his is the video I am linking to. I may try to recreate that setup when I get back on my feet (currently recovering from surgery, hence the frequent posting ).
Some people don't like the "raspy" sound, but I do. I'm just worried about the dB level at low speeds.
Old 05-22-2012, 04:30 PM   #17
My version of the sports muffler is this,
based on the internals of the OEM muffler. I simply welded a bypass into the sides of the muffler, which gives you the in-between sound of the complete bypass and OEM sounds...virtually invisible.
Internal Direction of exhaust:
Here's a short video & sound: start up and short blip...
View My Video
Good luck
grtc68 is offline   Reply With Quote
Old 05-23-2012, 11:01 AM   #18
I have a charlie chan muffler, aka, benny hanna ! also added Fabspeed bypass pipes and love it. Mine sounds like the link below but is deeper. I'll try to film a little this weekend and see if I can post it. Mine is a 2003, base boxster that is desnorkled also. One clue though if you order the Fabspeed bypass pipes make sure you tell them to put the plugs in with it. Mine came without plugs (each pipe has two holes that need plugged) and I had to get them locally.
2003 Midnight Blue Boxster 986, 2.7, Fabspeed bypass pipes, Charlie Chan muffler, desnorkeled
houstoer is offline   Reply With Quote
Old 05-23-2012, 12:39 PM   #19
Overdrive's Avatar
Considering that's not really the official name (that I know of), and as far as I can tell is nothing more than Johnny Danger's attempt at a chuckle-worthy (though slightly offensive) title for a cheap Chinese origin item, the name choice is strictly colloquial. Making it Benihana doesn't do any better, really.
There has been a noted weight loss and performance gain, and while 10hp isn't really amazing, it matters for this car, where one needs every horse they can get if they're trying to gain performance there, since these engines don't gain much without serious building and money. I don't take that to mean the car has been engieneered to its optimum, I see it rather as Porsche introducing enough limitations that the car's optimum is only a minimal gain. Even if one were to build the motor up well, improve several things, and use good bolt-on parts, I can't see a 2.5 exceeding 250hp without going forced induction...not nearly worth the money it'll take to get there.
I personally want something that's going to provide some performance bump and better breathing without making the car sound terrible. If that's out there, I'll go for it. I'm not trying to make a pure track car, but something that can be tracked well and driven to and from said track comfortably.
-O/D
IMSR + RMS
Old 05-26-2012, 07:02 PM   #20
Here is a video with the chan cans before I cut them up........ Actually, they don't sound bad.
98 boxster
