Old 12-28-2011, 06:12 AM   #1
brake light electrical issues
hey guys,
was wondering if anyone else has had this issue before. i just noticed recently that my brake lights flicker. if i press them lightly, they will "lighten". but if i push more pressure on the brake pedal, the rear brake lights go off. i assume it's an electrical issue. but where do i look? also, it is only intermittent. sometimes it does it and other times, there is no problem. probably just loose connection somewhere. suggestions?
-Tuan
tuanle16@juno.com
tuanle16 is offline   Reply With Quote
Old 12-28-2011, 06:52 AM   #2
1999 base
Meir's Avatar
Most of the chances it’s the switch.
Look at the top part of the brake pedal, you will see a black plastic switch.
In order to remove it, you have to twist it 90 degrees.
Once you have it outside, press and release it to see if it moves smooth.
Check if the light is working properly.
Most of the chances you will fine the switch stays stuck on its “pressed” position.
this is how it looks:
10$-20$ at Pelican parts
Old 12-28-2011, 05:52 PM   #3
will do! thanks. will good ole fashion WD40 work? or do i need to just replace it?
-Tuan
tuanle16@juno.com
