Old 12-26-2011, 08:37 PM   #1
Bmod986's Avatar
Originally Posted by WhipE350 View Post
Hey - no harm in going slow...staring at walls sometimes, beats making mistakes. I think the biggest thing I have learned in the past year is taking my time and not wanting instant results. I did the trany flush on like the coldest night of the year, garage was freezing. Got all the parts off, things started shrinking and then they didn't want to go back together so easy. I learned trany fluid is the worst smelling thing in the world.
And on the jacking the car up...I still hate that part the most, everything else is getting easy, just something about the left wall being so close to the car. From the pic looks like you got up pretty far. I use carpet pad to roll around on, beat the cold hard concrete. The roller is too high sometime.
Oh and I stare at walls sometimes too when working on the car. Thinking time is always good.
Its pretty cold in jersey now i had a heater for three minutes and it through my braker off, so no heater for the garage, and I used that card board in the pic to role around. And as far as the height it may look high but i could not role over under the car and Im a thin guy. Also to get to the spark plugs I had to bend my back quite a bit while siting with my legs crossed. If it only would have been a few inches higher I would have been much more comfortable. So recommendation of the day raise that car high even though its drastically scary.
Bmod986 is offline   Reply With Quote
Old 12-26-2011, 09:10 PM   #2
Autobahn Glanz
WhipE350's Avatar
Try putting the space heater on low or find an outlet that isn't on the same circuit. I have mine up exactly 20 inches, it really helps. If I'm on the roller it isn't enough to roll over though. I was hoping to go to 24 inches. I only don't like the first part of the jacking, one it is up i just go back and for a couple notches at time.
You removed the panel in the wheel well for the spark plugs...right? I'll admit unless on a 6 foot jack that engine most spark plug is a pain.
Old 04-09-2012, 07:25 PM   #3
i find febi good, especially to have it with rings already, but still its up to you what do you want. And febi quality is good and it really fit well.
kotto is offline   Reply With Quote
Old 04-10-2012, 03:25 AM   #4
Ex Esso kid
I have a full set of brand new Boxster wheel lug nuts from a 98 pm if interested.
Tags
air filters , service , spark plugs
