Old 12-09-2011, 09:53 AM   #1
2000 Arena Red Base
Bengalfan's Avatar
convert top liner
In checking for new top w/ glass, I see liners offered, but only for after 2000 (except the 2000 "S").
What is different to the frame/top that allows for liners post 2000, but not before?
Does a liner really help for noise reduction or for holding in the heat / cool depending on the season.
Bengalfan is offline   Reply With Quote
Old 12-09-2011, 01:29 PM   #2
The original headliner trim must be reused. There was a problem with the front headliner plastic retainer warping. You can get the acoustic top in black from GAHH which will absorb some noise.
Peter Serbanica is offline   Reply With Quote
Old 12-09-2011, 02:10 PM   #3
2000 Arena Red Base
Bengalfan's Avatar
Thanks for the reply Peter.
I guess what I'm trying to ask is - what is the difference between the tops and/or frames that allows for a liner to be used post 2000, but not before.
ie: I have a 2000 base that doesn't have a liner, but the 2000 S has a liner, as does all subsequent Boxsters. A liner supposibly can't be used with any 97-2000 Boxsters, except the previously mentioned 2000 S.
What is different, and can it (the frame?) be modified to take a liner??
Old 12-09-2011, 02:26 PM   #4
I asked the upholstery shop about it when they were putting new top in.
You CAN put a liner in pre-2001 boxsters.. the only problem, you need new plastic pieces that hold the liner, earlier cars (I have a 2000 base) have the plastic piece (the one in the middle of the frame) that doesn't have "holes"/clamps (or something like that).
New plastic trim costs 200$++ at the dealer, that why shops usualy say it's not doable.
Sasha
sasha055 is offline   Reply With Quote
Old 12-09-2011, 04:32 PM   #5
I am in the same situation as Bengalfan...
sasha055 (or anyone else with a later car with a liner) - can you post a pic so those of us with earlier cars can see what plastic pieces and/or holes/clamps we're missing?
Thanks much.
Old 12-09-2011, 06:16 PM   #6
I have a 2000 base and I have old style plastic trim.
I didn't want to pay for new trim.
New trim with headliner would've been another 500$, so I passed.
Sasha
