11-03-2011, 12:47 PM
Ex Esso kid
Ordering 2.5 tomorrow
I found a 2.5 with a new ims and internally checked and rebuilt where needed, cost is 3K plus my engine. Do any of you guys think it's worth it to try to sell the damaged 2.5 for more than 500 on the bay? My mechanic is going to put it on a lift, do all the heavy stuff and let me work and participate at his business as I am able then give me a final cost for the job. For me that's like a dream come true, lastly, need tips on making device to hold engine in place of Porsche special tool, thanks to all that tried to help, my car has a broken left bank tensioner for sure.
11-03-2011, 01:24 PM
Hope the engine is coming from someone who knows how to do a tear down and rebuild. At lot of scammers out there. Good luck.
Old Hippie Young Heart
11-03-2011, 01:36 PM
What is the source for this engine? the IMSB ? The metal loop by the throttle body can support that end of the engine as long as the front engine mount is supporting the front. when the engine is loose & ready to be lowered & removed the weight of the engine can be supported at the oilpan with some cushion to prevent damaging oil sump plate.
11-03-2011, 02:20 PM
Good luck Ghostrider. Keep us posted.
2006 Hummer H3 - RED 76k mi - LIFTED - 3rd row custom seating on 35's and a manual tranny.
1997 Boxster Guards - RED 86k mi - 19" Lobster Claw Wheels on Conti's , Porsche side decal for extra "speed", manual tranny -signed by Hurley Haywood
Phoenix, Arizona
11-03-2011, 05:15 PM
The replacement engine looks pretty good at that price. Good luck and I hope that you get the car back on the road soon!
11-03-2011, 05:21 PM
Ex Esso kid
Will a 2.7 run off a 2.5 harness and brain box? Whats the deal with motor meister? They make it sound like they do good work but I read a horror story in here once, anybody have any luck with them?
11-03-2011, 05:35 PM
I don't know.... I'm a newbie with these water cooled engines, but the orange silicone would scare me. The amount on the outside is usually what ends up on the inside of the case. If he had to split the case for a new IMS shaft,( maybe he just meant IMS bearing in the discription) there would be more new seals than just the head gaskets, IMO. To me it just looks like he took the covers off and looked inside, then siliconed the old gaskets (could be new) back in place.
Like I said, "Just an opinion of a newbie"
Tim
11-03-2011, 05:37 PM
Ex Esso kid
Your opinion counts, this is all new for me too and 3K is a lot of cheese, I'm going to take it slow and read all the comments.
11-03-2011, 07:33 PM
Opposed to Subie Burble
In case you missed it in thejack's thread where I replied to you, Ghostrider, I'd recommend you get in touch with Jake Raby at Flat6Innovations and have a conversation with him. If you're going to drop money on an engine, I'd say be willing to drop a little more on something that you know was done right versus trying to bargain hunt and get less than you pay for. People can type whatever they want about what they've done to an engine. If you weren't a fly on the wall or standing there hovering over them the whole time they did it, you can't believe a word of it unless they're a company with a reputation that involves satisfied customers that they didn't BS...at least in the latter case there's likely to be a legit warranty/guarantee involved.
-O/D
IMSR + RMS
Robbins glass window top
11-04-2011, 02:35 AM
Ex Esso kid
Thanks OD, I'm investigating having my own engine repaired locally. I have a capable wrench looking at the pelican thread on tensioners, hopefully I can keep the motor in it assuming the internals are good and that he is up to the task, otherwise I'll keep shopping.
11-04-2011, 02:59 AM
Just would like to express a personal opinion about that, accordind to what has already been said by overdrive.
Maybe you need to have a conversation with Jake Raby, he can tell you what would be the risk in swapping your engine with a unit where some other unknown hands have worked on. That engine doesn't get me convinced... You know... usage of orange sealing paste on the heads instead of original gaskets tells me something (negative) about the mechanic's skills and quality of job. Furthermore, a refurbished engine should have something more replaced than a IMS shaft (what about bearing?) and some other gaskets here and there...
Starting from the picture you have posted in my thread, that leakage could be addressed to a bad valve cover gasket and does not mean you have to face something expensive as an engine swapping. And honestly I can't believe that issue is coming from chain tensioner.
You have a number of checks to investigate your engine conditions, starting from a timing deviation check, oil debris check and some other simply checks that lead you to the best decision and action plan to save you car in the best and cheaper way.
Obviously, online diagnosis based upon a picture is always the best way to be trick...
Check your oil filter for brown plastic (tensioner) or shiny metal debris (IMSB), this will give you a clue on how the internal parts of your engine are on their way to go... and starting from this you can take your final decision about the action you have to take.
Let us know.
11-04-2011, 04:32 AM
Ex Esso kid
Straight up, it's 100% the tensioner, Wayne's website (a treasure trove of perfectly executed repair tips, thanks!) mentions that some cars have had this fail. I heard it for the last two years at start up, chain against ___ slide grind, then smooth as silk. What I couldn't understand is how that would make the cam gasket fail but oil leaked from somewhere. My engine is coming out, I will try to follow up with guys like Jake but honestly, I don't have the coin to put ten or twelve in it. The mechanic I have now graduated from a good place, has mad Subie experience and I truly believe is up to the task. I changed my oil at 1/2 intervals, I'd like to keep my own engine and agree totally with you guys on the red sealant used on the 2.5 engine.
11-04-2011, 05:12 AM
Ghost,
Explain the sound you heard a little more if you would. Most Boxsters do make an unusual sound upon startup and we dont want everybody to think that what happened to you is happening to them.
Glad you can make it work and I will follow your post and wish you all the luck.
Phoenix, Arizona
11-04-2011, 05:28 AM
Uhm, not that I'm questioning your mechanic's knowledge but I wonder how he can state it's the tensioner to blame without any visual inspection. Starting from the left bank leakage, assuming it has been caused by the tensioner fault is pure speculation. Maybe your engine suffered a bad cam cover gasket as a stand alone issue with no correlation with the tensioner issue.
The M96.20 (and others) uses tensioner composed by metal polymer structure. In case of fail of the sliding surface you could suffer a lot of secondary effects as oil pump failure, oil pressure drop or lack of lubrication in a specific area of the engine aside from a huge variation in the timing of the bank if the tensioner cannot correct the loosen chain with its own spring effect. Don't forget that this will put a lot of plastic debris in your oil circuit that you should see in the filter cartridge.
My boxster sounds to be very noising at start up until the oil reaches its correct pressure and flow inside the engine (oil grade to be adjusted, now I'm using 0-50W). And that noise is coming from chain tensioner which operates without oil for the very first revolutions. Then you ear the engine running smooth and silky. In case of a bad tensioner, a noise would be audible also during normal operation.
Don't know... I am convinced that an engine should be swapped only if there's not any other chance. Oviously, imho. Let us know
11-04-2011, 05:36 AM
Ex Esso kid
97, The sound was like a loose chain against gear or play in the system going out of the system at start up, wayne mentions the hydraulics in the tensioner sometimes going bad. More important is his mention of Porsche updating the tensioners. You think Porsche would have the bugs out of their tensioners by now, this isn't the first occurance of problems. As for Jack, my mechanic didn't say it was anything, I'm telling you I believe with my thirty years around cars (25 at a dealership) that it's the tensioner. The issue is only on the left bank. Also, the car will still start and run in timing, another huge clue. Whatever surprise lies within the "cracker-jack" I'll post pics of for all of your wintertime enjoyment..thanks to all
11-04-2011, 05:41 AM
You want to read some horror stories about Motor Shiester? Drop in on the 911 board and type in the name...it will be enough to get you running the other direction.
Looks like a real hack worked on the 2.5 and didn't even bother to update with the LN bearing...it will only cost you more $ in the long run trying to do it cheap.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
11-04-2011, 05:47 AM
97, The sound was like a loose chain against gear or play in the system going out of the system at start up, wayne mentions the hydraulics in the tensioner sometimes going bad. More important is his mention of Porsche updating the tensioners. You think Porsche would have the bugs out of their tensioners by now, this isn't the first occurance of problems. As for Jack, my mechanic didn't say it was anything, I'm telling you I believe with my thirty years around cars (25 at a dealership) that it's the tensioner. The issue is only on the left bank. Whatever surprise lies within the "cracker-jack" I'll post pics of for all of your wintertime enjoyment..thanks to all
Well ghostrider, this is something I'm interested into as it happens to my boxster too at each start up if I left the car unused for an hour. Good luck.
