Old 08-22-2011, 07:14 PM   #8
Originally Posted by BYprodriver
Installing taller than stock tires & wheel spacers induces negative camber to the tire alignment which increases inner treadwear. I am guessing you are also seeing/feeling feathered edge treadwear not cupping due to front & rear toe setting being out of spec. What you need is a proper alignment by a mechanic capable of compinsating for the modifications. Don't waste your money rebalancing the tires as this has no affect on treadwear. If your car has over 60K miles or a leaking strut that could be a factor in the irregular wear.
Struts look fine and car has just 40,000 miles. I will ck around and see who could do such an allignment. Thanks for the advice, Im also going to adjust tire pressures to correct levels.
jetty1 is offline   Reply With Quote
