Old 08-07-2011, 08:45 PM   #1
Angry Cylinder not firing??
I have a 2002 Boxster, without any mods, with 53k on the odometer. I bought it about a month and a half ago. During that time, and before today, it ran and drove just fine.
When I went to move it today, the check-engine light started blinking, then glowed steady. And jnudging from the way it was running, it was clear to me that one of the cylinders was not firing.
Anyone else have this problem before? Any ideas what it might be?
Thanx...
roland3337 is offline   Reply With Quote
Old 08-07-2011, 08:51 PM   #2
Welcome to the forum.
So, most of the responses right off the bat will be:
1. Get a code reader from AutoZone or other parts store and read the codes that are present that caused the CEL. Once you have it, post the code.
2. Flashing light = Do NOT drive!
stateofidleness is offline   Reply With Quote
Old 08-08-2011, 12:28 AM   #3
Originally Posted by roland3337
When I went to move it today, the check-engine light started blinking, then glowed steady. And judging from the way it was running, it was clear to me that one of the cylinders was not firing.
Could be simple. Spark plug ou spark plug coil. When it happened to me it was a coil.
You need to read the code with a scan tool and post it here.
Try this
http://www.durametric.com
or check for a Durametric onwer close to you.
If you need to change a plug/coil you have some info here:
http://www.pelicanparts.com/techarticles/Boxster_Tech/07-ENGINE-Plugs_-_Coils/07-ENGINE-Plugs_-_Coils.htm
Don't drive your car and don't worry to much. Probably it's simple and inexpensive to repair.
Good luck.
jmcl is offline   Reply With Quote
Old 08-08-2011, 06:37 AM   #4
ppbon's Avatar
If the blinking CEL turned solid...
... you probably have a lose coil pack connector.
When it was lose you had a misfire, the CEL blinks.
When it's making contact the CEL goes solid.
Check all 6 connectors and get a code reader to clear the codes after it's fixed.
Happy Boxstering,
Pedro
ppbon is offline   Reply With Quote
Old 08-08-2011, 03:14 PM   #5
Don't be surprised if its not a coil pack. There are several other reasons to have a misfire (or what seems to be a misfire). That is why reading out the code is critical - so you can be sure to address the right problem and not go about it blindly.
Old 08-10-2011, 06:13 PM   #6
Code reader result...
Many thanks to all of you that took a moment to reply.
I picked up a code reader today, and I got this reading back: P0306
The manual indicates that this is a cylinder 6 misfire.
Any other recommendations?
Roland3337
