Originally Posted by roland3337
When I went to move it today, the check-engine light started blinking, then glowed steady. And judging from the way it was running, it was clear to me that one of the cylinders was not firing.
Anyone else have this problem before? Any ideas what it might be?
Could be simple. Spark plug ou spark plug coil. When it happened to me it was a coil.
You need to read the code with a scan tool and post it here.
Try this
http://www.durametric.com
or check for a Durametric onwer close to you.
If you need to change a plug/coil you have some info here:
http://www.pelicanparts.com/techarticles/Boxster_Tech/07-ENGINE-Plugs_-_Coils/07-ENGINE-Plugs_-_Coils.htm
Don't drive your car and don't worry to much. Probably it's simple and inexpensive to repair.
Good luck.
