Old 06-17-2011, 01:52 PM   #1
jaykay's Avatar
LASO water pumps
How do all feel about this aftermarket part? Is it better quality than oem or worse. I am considering it as i will be changing it every few years so...
986 00S
Old 06-17-2011, 02:05 PM   #2
Not good; several reports around of them not making 2K miles after install. While a pump change on these cars is not all that hard, fresh coolant adds significant costs, along with the grief of bleeding the system afterwards if you do not have the vacuum filling system. You really don't want to skimp on the pump......
Old 06-17-2011, 09:28 PM   #3
Steve Tinker's Avatar
+1
Theres a couple of guys here in Australia who had early failures of Laso water pumps. When I changed out mine earlier this year, I decided to go the genuine article from Jake Raby's Flat 6 organisation in Georgia and had it shipped to me - got it within 7 days, awsome service. I'm good for another 3-4 years now without any worries.
Why would you go with aftermarket for such an important piece of hardware for only a few $$ more....??
2001 MV Agusta F4.
Old 06-17-2011, 09:56 PM   #4
Idaho Red Rocket 3's Avatar
I've seen some aftermarket pumps with metal impellers. What about those ?
2000 Boxster S
Old 06-18-2011, 04:33 AM   #5
I asked jake about that last week. They used to recommend the metal. Now they don't; when the bearings go bad, the impellers chew up the aluminum block. He says use plastic, but change it every couple years before the impeller breaks down.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
Old 06-18-2011, 07:23 AM   #6
If someone's trying to save a few bucks, I can offer them the OEM water pump I pulled off my car a couple of weeks ago. Still looks good and I'll let it go cheap! And only 90.000 km and 10 years on it.
clickman is online now   Reply With Quote
