Old 04-24-2011, 10:01 AM   #1
Motive bleeders in Canada
I want to bleed my brakes and clutch, and it seems the Motive is the way to go.
Which one is right for doing the Boxster? 0100?
Where best to buy one from Canada? The Canadian distributor Motive uses charges a 36% markup.
Old 04-24-2011, 01:02 PM   #2
Autobahn Glanz
WhipE350's Avatar
Yes that is the one I have...got it from Amazon for < $50...I used them because the shipping is the cheapest. Not sure where you can buy in Canada.
It is great for brakes, takes less then an hour. Work great on the clutch too but you'll need monkey arms...I did mine and boy it was fun
Old 04-24-2011, 01:22 PM   #3
Why don't you just buy off ebay. The canadian dollar is higher than US. If you ship USPS this will be the total price.
http://cgi.ebay.com/ebaymotors/Motive-Universal-Brake-Bleeder-0101-Free-Shipping-_W0QQcmdZViewItemQQhashZitem53e6b361b0QQitemZ36035 2801200QQptZMotorsQ5fAutomotiveQ5fTools
brian325is is offline   Reply With Quote
Old 04-24-2011, 01:35 PM   #4
Based on my own experience, I'd recommend spending a little extra to get the higher quality Black Label model 0109.
This gives you an ebay.ca link:
http://cgi.ebay.ca/Black-Label-European-Power-Bleeder-Motive-0109-/360360726351?pt=Motors_Automotive_Tools&hash=item53e72c4f4f
'99 black 986
Old 04-24-2011, 03:44 PM   #5
What happened that made you feel that way?
Old 04-24-2011, 03:46 PM   #6
"This listing (36035) has been removed, or this item is not available."
Old 04-24-2011, 04:26 PM   #7
Better quality fittings - aluminum instead of plastic, longer hose. Seemed well worth the extra couple of bucks.
'99 black 986
Old 04-24-2011, 09:00 PM   #8
Autobahn Glanz
WhipE350's Avatar
Mark has a point, mine (0100) doesn't have a swivel on the hose and it is a pain, but as little as I use it I just was careful and grumbled through it.
Old 04-25-2011, 07:50 AM   #9
When you get it, ignore the instructions when they tell you to fill it with brake fluid. Use air pressure and just top up the master cylinder frequently (don't let it get below "min" mark). It will keep the bleeder clean and it works well.
Mike_Yi is offline   Reply With Quote
Old 04-25-2011, 08:12 PM   #10
Mike, trying to understand. I've never done this before, so just askin':
Why not put the brake fluid into the Motive? Less chance of running out of fluid and getting air in the system. And what's the big deal about having to dump the excess fluid out of the Motive and into the container you're collected the old fluid in for disposal? The opened container of new fluid has to be tossed anyways...
Old 04-25-2011, 08:28 PM   #11
Autobahn Glanz
WhipE350's Avatar
Just my 2 cents, I've done it both ways, since I have the 0100 and it doesn't come off easy I put the full fluid amount in the bleeder...either way will work.
