Old 09-10-2010, 03:41 AM   #1
Originally Posted by davemon
When the top is about 15% away from being closed and the clam shell begins narrowing down, I notice that the top is not retracting evenly. The driver's side is a bit higher. The clam shell will push the top closed then will stick up about an inch or 2, won't close all the way. I noticed a small tear developing in the top behind the driver's seat. The top is getting pressure from a metal structural piece as it clamps down all the way.
Is there a way to adjust this? If I had to guess the cable just loosened up from the motor and needs tightened... but that is just a guess.
Any help would be appreciated.
Thank you.
Check the push rods perhaps a bolt got loose. They have the white or red caps on them.
Peter Serbanica is offline   Reply With Quote
Old 09-12-2010, 09:13 AM   #2
Ok I've determined that the issue is that the canvas top is not retracting far enough down, so now the clamshell can't close down on it and sits about 1" high.
LB, thanks for the advice! Pelicanparts shows 2 different cables. motor to transmission cables and convertible top tension cables. Sorry, but I'm not sure which cables I'll need to replace.
'04 986 Aero - Seal Metallic Gray
Fabspeed: Maxflo Mufflers, Headers with sportcats, Tips; Alpine & Infinity sound
davemon is offline   Reply With Quote
