Old 09-09-2010, 07:16 PM   #1
davemon
Convertible top closing crookedly
When the top is about 15% away from being closed and the clam shell begins narrowing down, I notice that the top is not retracting evenly. The driver's side is a bit higher. The clam shell will push the top closed then will stick up about an inch or 2, won't close all the way. I noticed a small tear developing in the top behind the driver's seat. The top is getting pressure from a metal structural piece as it clamps down all the way.
Is there a way to adjust this? If I had to guess the cable just loosened up from the motor and needs tightened... but that is just a guess.
Any help would be appreciated.
Thank you.
'04 986 Aero - Seal Metallic Gray
Fabspeed: Maxflo Mufflers, Headers with sportcats, Tips; Alpine & Infinity sound
davemon is offline   Reply With Quote
