You may need to replace the cables and re-synchronize the top.
Not uncommon. The sheathing surrounding the actual cable shrinks with time mainly due to engine heat. When that happens, the cable (one for each side) can pull away from the transmission or motor can cause the issue you state.
Best not to operate the top until it's corrected or you risk bending the aluminum clamshell.
Cheers!
