Old 09-06-2010, 08:17 PM   #1
Looking to customize front end
of a 2001 Porsche Boxster 986.......what is the best look in your opinion
DerrickCaracter is offline   Reply With Quote
Old 09-06-2010, 09:14 PM   #2
GT3 MK1 bumper.
Boxster S
Old 09-07-2010, 02:11 AM   #3
Originally Posted by Cloudsurfer
GT3 MK1 bumper.
I concur, with spoiler lip... IMO the biggest visual impact one can make to the front end of the 986 is litronics if not already equipped.
Old 09-07-2010, 04:14 AM   #4
Who sells them?
Also, any recommendations for the rear bumper cover? Any way to remove the warts? Mine got clipped so I want to take advantage of the opportunity to change things up.
poor-sha is offline   Reply With Quote
Old 09-07-2010, 04:29 AM   #5
2003-2004 Bumper... followed by 996 MkII (2002-2004) front-end conversion which will need your fenders and headlights replaced.
Old 09-07-2010, 07:03 AM   #6
I can't seem to find a picture of what I did, but I removed the warts or bumperettes and replaced them with a blank plate. I then mounted the license plate over top of it. I used a perforated metal that looked pretty darn good IMHO. I know another member here used a black plexiglass blank (their picture attached). I had a few of these blanks made up and bought the trim for them, but never did anything with them. If you want one, let me know and I can probably part with one cheap as I now have a Gemballa rear bumper and don't really see myself going back to stock.
Kirk
Old 09-07-2010, 08:09 AM   #7
are your blanks artic silver?
Old 09-07-2010, 06:20 PM   #8
the ctr turbo style looks really good to me
Old 09-07-2010, 09:31 PM   #9
Guess we're not really on the same page here.....
Boxster S
Old 09-08-2010, 07:49 AM   #10
No what I've got are the black pelxiglass inserts like in the photo.
For my arctic silver car I had installed the perforated metal blank and painted it silver.
Kirk
Old 09-08-2010, 08:21 AM   #11
Kirk - PM me with how much you'd like for the blanks. Does the underlying metal structure unbolt from the bumper beam? I have to admit that I haven't done more than a cursory look. Thanks.
Old 09-08-2010, 08:57 AM   #12
Johnny Danger's Avatar
In addition to style, you should also keep in mind the importance of quality. Depending upon your level of perfectionism, all of these body kits and aero parts require an awful lot of fine detail work in order to achieve "factory" like fit and finish. During my search for a kit for my vehicle, I discovered that there were vast differences with regard to quality and construction amongst a wide range of manufactures . Don't be fooled by anyone who tells you that these parts come primed and ready to be installed "out of the box". Be prepared to spend some time and money having it installed by an experienced professional.
Old 09-08-2010, 01:26 PM   #13
07 Carrera S Cab
Boxtaboy's Avatar
Johnny, quick question- I've noticed on another Boxster owner's car who has a fiberglass replica of the GT3 bumper that he has some nasty rock chips on it...and I'm not talking about small chips, but some chunks that came off from rocks hitting it on the freeway at high speeds presumably...and it looks just awful. With a fiberglass front bumper, is this inevitable, or is the solution just getting a clear bra installed? Even with the clear bra, however, I'm thinking if you get bumped lightly by another car in a parking lot, your bumper will be cracked, as opposed to the OEM polyurethane bumper just deforming and then bouncing back to shape (as mine has a couple times already). Or, do the higher quality fiberglass bumpers have a flexible nature to them?
Old 09-08-2010, 02:09 PM   #14
Pat
Skip fiberglass in general. Not nearly as durable.
-Chuck Patterson
Old 09-08-2010, 04:11 PM   #15
Certain that it is, when fiberglass takes an impact, it is far more susceptible to being damaged than polyurethane. However, the nice thing about fiberglass is that it can easily be repaired as compared to polyurethane. Polyurethane is a great material provided that the part(s) fit well. I have seen several aftermarket body kits and aero parts made from poly, wherein the fit and finish was terrible. This presents a real problem, because poly cannot be "manipulated" or shaped like fiberglass to ensure a perfect fit. Personally, I have not had any problems with the fiberglass body kit on my vehicle. And, to answer your question regarding rock chips and road rash, I have clear bra installed on my vehicle in several key areas and it has proven to be invaluable.
Old 09-08-2010, 04:32 PM   #16
To further elaborate on the topic of fiberglass, there is a vast difference in quality and durability between a European manufactured body kit/aero part that meets TUV standards than most of the domestically produced "stuff" one encounters on Ebay and the like.
Old 09-08-2010, 05:36 PM   #17
07 Carrera S Cab
Boxtaboy's Avatar
Thanks, I figure there must be high quality fiberglass out there. I mean, Vettes and Lotus cars use Fiberglass extensively, and I don't see them running around with big rock chips on their front ends. Lol. Perhaps they have some more flex in them or have protective covering.
Old 09-08-2010, 07:01 PM   #18
Pat
Do you know where they use these materials? I doubt in bumpers.
-Chuck Patterson
Old 09-08-2010, 07:25 PM   #19
If you like the style, the Caractere bumper shown in your photo is a very high quality piece. Be cautious, however, there are a few "knock offs" of their design out there.
Old 09-08-2010, 07:35 PM   #20
http://www.tuvdotcom.com/pi/web/whatCertifiedProduct.xml?LanguageChanged=en-us&sLand=&sLang=
