05-30-2010, 05:12 PM
#1
Convertible Top Problem
Hi Everyone,
I have a 2001 Boxster 2.7 Tiptronic, with 91,000 miles on it and it still drives GREAT. Over the past 4 months I have had an issue with my convertible top, please see the inserted picture as I don't know exactly how to describe it other than my top seems to be separating somehow, there is a very small opening where I can see right thru it and I have no idea whats causing this or how to even begin to fix it, or if fixing it is even possible. The top is actually in great shape, and I don't suspect that I would need to put on a new top. I just have this opening that is spreading, seems to open more and more each time I drive with the top down then put it back up, I notice a little more "space" or "opening".
Please any help or ideas would be greatly appreciated!
2001 Boxster
2014 Toyota Tundra
"Its Craptacular" - Bart Simpson 1997
05-30-2010, 07:45 PM
#2
Looks like the anchor on the cable is broken.
The edge of the soft top is actually a steel-braided cable that has an eyelet on the bottom which anchors to the frame, keeping the cable taught.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
05-30-2010, 08:52 PM
#3
Happy Boxstering,
Pedro
Can the cables you mentioned be tightened? If so where do you tighten them and how much?
2006 Hummer H3 - RED 76k mi - LIFTED - 3rd row custom seating on 35's and a manual tranny.
1997 Boxster Guards - RED 86k mi - 19" Lobster Claw Wheels on Conti's , Porsche side decal for extra "speed", manual tranny -signed by Hurley Haywood
Phoenix, Arizona
05-31-2010, 05:57 AM
#4
Where do I locate this anchor? The top seems tight everywhere else.
2001 Boxster
2014 Toyota Tundra
05-31-2010, 09:39 AM
#5
I think what Pedro is referring to is the ball joint cable that you plug from the top to the car. When you open the top up in service position, you should see a small metal cable about 8 or 10" long on each side of the car. This cable keeps the top tight on your car. I don't think it's adjustable as its just a metal cable with connectors on each end.
Coincidentally, I forgot to snap the cables back on the last time I worked on my car. Paid for it dearly when it rained, as a lot of water got into my car.  Luckily I caught it right afterward and cleaned it up. Cautionary tale to all! Be sure you snap those cables back on!
Parts for sale: 4-spoke Steering wheel, air bag, and leather cover ($350 + shipping), Rear zipper storage bin ($100 + shipping), CDR-210 Factory OEM radio, casing, and keys ($100 + shipping), Hand brake handle and hand brake sensor ($50 + shipping), Manual factory leather shift knob ($Free + shipping)
05-31-2010, 05:52 PM
#6
Right on the frame of the soft top, towards the pivot point.
Open the soft top about 18 inches and follow the cable down.
You should see where it snapped.
Happy Boxstering,
Pedro
05-31-2010, 06:53 PM
#7
The cables are called "tension ropes" by Porsche, and there is an adjustment possible. You can turn the 14mm bolt that sits vertically, and just inboard of the lowest part of each tension rope CCW, and that will in effect "lower" the steel ball that it attaches to, and thus increase the downward pull on the rear main bow.
Regards, Maurice.
06-05-2010, 09:00 AM
#8
I Think I have found the problem, not sure, but I think this is it, can anyone tell me if a screw should be here and is somehow missing and if so, what size/type of screw goes in here?
2001 Boxster
2014 Toyota Tundra
06-05-2010, 09:55 PM
#9
There is definitely a screw missing from that location. It's a small Torx head screw, and its function is to hold one end of the cable fixed at the base of the B-pillar, with the other end of the cable being anchored on the shoulder plate on that side.
That missing screw would cause the "opening getting larger and larger", so replacing the screw will fix it.
Here is a link that shows the particular screw (T20 torx) and gives you a cautionary warning about not stripping the aluminum (or magnesium?) threads that it goes into:
http://sites.google.com/site/mikefocke2/replacingthetop-adiy
Look at the text in paragraph 6 in that DIY, and click on the photo to blow it up.
Regards, Maurice.
03-03-2011, 06:42 AM
#10
Similar Cable Problem
I have a 1999 Boxster with the similar side cable slack. However, the rear eyelet and bolt are in place. There is still a loose fit above the passenger side window. It doesn't leak water but is noisy and loose. Does anyone have any suggestions?
Thanks,
BentMick
08-19-2012, 01:58 PM
#11
Resurrecting an old thread here. What is the procedure to adjust the tension rope setting?
I replaced my top & backed the adjusters all the way out to get the top to close, now I want to set the correct tension.
