Old 04-30-2010, 08:40 AM   #1
rear tire wear
ok, the rim is trued up, new rubber is on. now I'm wondering about the wear on the old tires. outside couple inches was still looking good. middle was in the wear bars and the inside was down to the cords in places. looking at the car from the rear it seems like there is a little neg. camber. so... is this a normal wear pattern or do I need some kind of rear alignment? fronts are wearing evenly accross the tire. thanks for the inout.
02box is offline   Reply With Quote
Old 04-30-2010, 08:43 AM   #2
Alignment needed for street use.
Mike
04 Boxster S - Basalt/Savanna, 6sp, Carrera lites, hardtop
70 914-6 - Black over tan, original/stock
PCA since 1970
70Sixter is offline   Reply With Quote
Old 04-30-2010, 09:16 AM   #3
Not uncommon to wear on the inside since the suspension is independant. It will handle better with neg camber although an alignment will improve tire wear.
1997 Boxster 986
TechArt Championship Formula OZ Wheels,
TechArt Springs
TechArt Strut Brace Front and Rear
Technobrace (Thanks Pedro)
Michelin PS2
G2 Red Caliper Paint
DamageINC123 is offline   Reply With Quote
Old 05-01-2010, 12:54 PM   #4
That's exactly how the rears on mine wear.
2000 Boxster.
1997 Carrera 993.
986_Ron is offline   Reply With Quote
Old 05-01-2010, 06:32 PM   #5
need to drive the car harder to get more even tire wear...
kabel
Orlando - 99 BMW M Coupe (autocross toy), '11 Mazdaspeed 3 (dog hauler), '99 10AE Miata (the new daily driver)
kabel is offline   Reply With Quote
Old 05-02-2010, 01:22 PM   #6
Mine wear evenly, altho rt rear wears faster than left. If inside is wearing and outside is not, you have too much negative camber.
A lot of guys used to dial in neg camber at the rear for track work, esp A/X. Not sure about that with modern suspension geometry.
Mike
PCA since 1970
Old 05-02-2010, 04:14 PM   #7
Porsche "Purist"
Paul's Avatar
The more weight you put in the car, the more negative the camber goes. Have someone do an alignment with the same weight in the car as you usually have. Also have them adjust the camber and toe to the lowest values of the alignment specs.
1987 924S. 2002 996TT. PST-2
Old 05-29-2010, 09:52 AM   #8
Wear on inside tires
Ok I have a 2000 boxster w 315/25 ZR 19 98Y TOYO PROXES T1R on the rear...both tires are wearing on the inside...this is my 2nd set of tires for the rear...I need to know what I can do to get this fixed...I had an alignment done already...I was told I needed Cambers &/or arms to correct this...if so I willing to do just about anything to get this fixed...does any know how to fix this & what parts & brands would be best for the project...
ibox is offline   Reply With Quote
Old 05-29-2010, 12:14 PM   #9
manolo's Avatar
315's??? How on earth do those fit?
I would think if you head back towards a more "normal" set-up (265/18 for example) you would probably have a lot less problems, and defintely save a fortune on oversized and prematurely wearing expensive rubber.
2003 Cayenne Turbo
manolo is offline   Reply With Quote
