Old 02-19-2010, 04:21 PM   #1
mts
Boxster article in Excellence Magazine
There is a nice write up about Bill Diaz's 2.5->3.4 conversion in the April 2010 issue. Not sure if Bill is on the forum, but if so, congrats on the article!
2004 550 SE #1081 of 1953 (sold)
1997 911 Targa (sold)
mts is offline   Reply With Quote
Old 02-20-2010, 05:41 PM   #2
NWI Bill's Avatar
I liked the article too, so much so, I've read it over again. Some great ideas for both power increases and some nice interior tweaks.
NWI Bill is offline   Reply With Quote
Old 02-21-2010, 05:38 PM   #3
I don't understand why he chose to maintain the stock 3" MAF from the 2.5l?
2007 997tt
2000 986s
1997 993tt
1986 951
http://www.picvault.info/images/537088217_bugsav.jpg
eclou is offline   Reply With Quote
Old 02-21-2010, 05:45 PM   #4
NWI Bill's Avatar
I thought the article said he changed it to 3.5" and a new intake box after the initial dyno didn't yeild the results he hoped and determined the stock intake was the issue. Didn't he install a IPD plenum and an overbored TB? I may be confusing it with another conversion I read about in another publication.
1999 996-Carrera Arena Red Metallic-Current
1998 Boxster-Glacier White-Sold
1997 Boxster-Ocean Blue Metallic-Modified-Sold
Old 02-21-2010, 08:04 PM   #5
That's what I thought as well??
On my conversion I right away swapped to the stock 3.5" MAF Housing from a 3.4L engine. I had to remove the airbox and go with a cone filter but I wanted as close to stock setup for the 3.4L as possible.
I'd have to read the article again, but some of the stuff described in the conversion just didn't make sense???
VRsyncro is offline   Reply With Quote
Old 02-22-2010, 06:08 AM   #6
Exactly. 2 big questions marks for me:
1)upgrading the exhaust headers and piping but retaining the stock cats and muffler = probably net gain of zero
2)upgrading plenum, intake but retaining smaller MAF = probably net gain of zero.
The car should not need a piggyback signal massage device like the Apexi if it were setup correctly.
2007 997tt
2000 986s
1997 993tt
1986 951
Old 02-22-2010, 07:20 AM   #7
i have a nieve question.
When they are doing these conversions, do they not take the entire setup and transplant it?
take the motor, intake, headers, wireing harness, DME and transplant the entire system so that there are no issues with fittement.
2002 S
jhandy is offline   Reply With Quote
Old 02-22-2010, 12:30 PM   #8
Perhaps he retained the stock cats because he needs it to pass emissions. And he used a factory muffler because he didn't want something real loud. He probably only swapped out the headers because the exhaust ports on the 3.4L heads are too big for 2.5L manifolds and the bolt locations may be different as well. Is that right Jaay?
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
