Old 01-22-2010, 08:50 AM   #1
AMG
Question Dashboard Illumination - Help
Hi All,
I've got a 2003 Boxster S and the instrument panel lights (not the LED speedo etc) are not lighting up when I switch the headlights on. Also, the number plate lights do not work. I thought this was suspicious so checked the fuse box and it appears they are on the same fuse. So I replaced the fuse, replaced the number plate light bulbs (which were both blown) and still nothing!
I have checked the dimmer and this is not down, so its not that.
Rechecked the fuse, still ok. Tried the original one in another fuse and it works so definately not the fuse.
the fault seems to be intermittent as in the other day it illuminated fine. Has anybody had this issue before and can the advise what it is.
p.s here a pic of her.
AMG is offline   Reply With Quote
Old 01-22-2010, 10:00 AM   #2
There Is No Substitute.
rick3000's Avatar
Welcome, you have a Great Looking Boxster!
If your issue is not the fuse, and the they work intermittently, the only conclusion I can reach is that there is something wrong with either the wiring or the headlamp switch. The switch would be the easiest place to start looking for a problem.
Old 01-26-2010, 08:56 AM   #3
AMG
Thanks - guess i'll start with the switch then.
Old 01-26-2010, 06:18 PM   #4
I have the same problem, I have a headlight switch coming to hopefully cure the problem. I replaced the ignition switch and it did not cure the problem.
John M Hudson
2003 Boxster S
Nesbit, MS
johnmhudson111 is offline   Reply With Quote
Old 01-27-2010, 09:59 AM   #5
AMG
ok - well if you can let me know if that fixes the problem that would be great.
Old 07-05-2010, 03:37 AM   #6
updates?
hey guys!
i have the same issue.
have any off you found a resolution to this issue?
your help is much appreciated.
Harry.
Harry_m is offline   Reply With Quote
