Old 01-22-2010, 08:50 AM   #1
AMG
Question Dashboard Illumination - Help
Hi All,
I've got a 2003 Boxster S and the instrument panel lights (not the LED speedo etc) are not lighting up when I switch the headlights on. Also, the number plate lights do not work. I thought this was suspicious so checked the fuse box and it appears they are on the same fuse. So I replaced the fuse, replaced the number plate light bulbs (which were both blown) and still nothing!
I have checked the dimmer and this is not down, so its not that.
Rechecked the fuse, still ok. Tried the original one in another fuse and it works so definately not the fuse.
the fault seems to be intermittent as in the other day it illuminated fine. Has anybody had this issue before and can the advise what it is.
p.s here a pic of her.
AMG is offline   Reply With Quote
