Old 01-09-2010, 09:14 AM   #1
Are these headers bigger than 986S headers? Please help!!
Hi I have been in conversation with a member on here and we are really confused which headers he has. Here are the part numbers
Right header: stamped "987/01" and part number 987.113.103.08
Left header: stamped "987/02" and part number 987.113.104.08
I currently have a 3.6L in my Boxster and have aftermarket Fabspeed headers for the 3.2L on there and we would like to know if these are the headers with the bigger ports?? Any help is greatly appreciated. I know Todd posted something a ways back saying the 2005+ Boxster/Caymen S headers are way bigger???
BoxsterLewis is offline   Reply With Quote
Old 01-09-2010, 04:41 PM   #2
Yes, you want 987 headers on your 3.6 in a 986 car.
Boxster S
Old 01-10-2010, 08:36 AM   #3
I'm the guy with the stock 987 headers. They are supposed to be from a 2006 Boxster S. Since that is a 3.2L car, I'm not sure that these have the larger port openings that are needed for use with a 3.6L engine. The primaries are clearly larger in diameter than my stock 2000 3.2L headers, and the design is better overall than those headers.
My preliminary research indicates that the 3.4 Cayman S and 2007+ 3.4L Boxster S were built with the 3.6L cylinder heads. If that is true, then stock headers from a 3.4L Cayman S or Boxster S would be a good fit on a 3.6L swapped 986. Perhaps Porsche used the same headers on the 2006 3.2L Boxster S and the 2006 3.4L Cayman S? I am unable to prove which model years these headers are supposed to fit because the parts catalogs are not working (I get a 404 not found error) on Porsche's website. If I had a header gasket for a 3.2L or a 3.6L, I could figure this out pretty quickly. I do know that the port measurement at the flange is 1 9/16" x 2 3/8"
Here are some pics:
For comparison, here is a pic that "tholyoak" has previously posted. Top is a 3.6L gasket and bottom is a 3.2/3.4L gasket.
Blue-S
2000 Boxster S 6-speed - Ocean Blue / Savanna Beige
* 9x7 short shifter * Pedro's enthusiast mount * Carrera Ltw. wheels * Stebro bypass pipes
* M030 coming soon! *
Blue-S is offline   Reply With Quote
Old 01-10-2010, 08:46 AM   #4
There is a difference between 3.2 and 3.4 987 headers. The ones you want are Cayman S (which are 3.4) headers. Why do you want to use stock though? A lot of guys with 3.6 swaps use the B&B Cayman S headers.
Boxster S
Old 01-10-2010, 03:38 PM   #5
Those B&B headers are likie $2,000 i think. So we came to the conclusion that Blue-S's headers are smaller than the 3.4 headers?
Old 01-10-2010, 03:58 PM   #6
Porsche "Purist"
Paul's Avatar
Having tried a complete B&B system, then stock Cayman S headers with B&B secondary cats and mufflers, and finally a completely stock Cayman S system, I prefer the stock setup.
1987 924S. 2002 996TT. PST-2
Old 01-10-2010, 04:45 PM   #7
Why stock parts? Besides being thoroughly tested by the Porsche engineers, there's this to consider:
Fabspeed 987 Headers w/cat = $2565
Fabspeed 987 Headers w/o cat = $1965
B&B Cayman Headers w/o cat = $1999
Used, stock 987 Headers w/cat = a lot cheaper than the above
If an emissions inspection is necessary, the stock parts look stock too...
Blue-S
Old 01-10-2010, 04:48 PM   #8
So I spoke with Todd and he said the 987 headers are about port size, i think the difference between the 3.2/3.4 is the primaries..Thanks for the information Blue-S!
Old 01-12-2010, 12:18 PM   #9
K so the difference in part numbers between Cayman S and Boxster S 987 "987/21" and "987/22" for Cayman and 987/01 and 987/02 for the Boxster. Anyone have ANY idea what the difference b/w the two are?
Old 01-15-2010, 10:49 AM   #10
The parts catalog (PET) is back up on Porsche's website. I was able to determine the following:
* My headers (part numbers 987.113.103.08 & 987.113.104.08) are actually from a 2006 Boxster, NOT a 2006 Boxster S.
* The 2006 3.2L Boxster S header part numbers are different from the ones that I have.
* The 2007+ 3.4L Boxster S header part numbers are different from 2005-06 Boxster (2.7L) and 3.2L Boxster S.
* The 2007+ Cayman S (3.4L) header part numbers are almost the same as the 3.4L Boxster S headers; only the last two digits are different.
* The exhaust manifold gaskets (between the cylinder head and the header/manifold) have superseded so that the same part number now is used on many Boxster, Cayman and 996/997 911 vehicles. Gasket part number 996.111.107.55 was originally listed for a 3.6L 911 with the X51 performance package, but it is now listed for Boxster & Cayman too. This means that the port openings in that gasket are the same size as the exhaust port openings in the 3.6L cylinder head.
With this information in mind, I drove to the Porsche dealer and compared one of my 987 Boxster headers with the exhaust manifold gasket (part number 996.111.107.55). The openings in the gaskets were an exact match for the port openings in the headers! This means that my stock 2006 Boxster headers will fit the exhaust ports of a 3.6L engine very well.
This raises the question: If the 2006 Boxster 2.7L, 2006 Boxster S 3.2L and 2007+ Boxster S/Cayman S 3.4L headers are different from each other, what's the difference? I would have to see and measure a Cayman S/Boxster S header to get a better idea about that. Given that the port openings in the Boxster 2.7L header are as big as the 3.6L ports, it's entirely possible that the difference between the headers might be something that cannot be easily seen or measured: the precious metal content in the built-in catalyst. This is not as far-fetched as it sounds, since platinum & rhodium are REALLY expensive. What if the difference is in the catalyst substrate type and/or the cell count? The 2006 Boxster 2.7L headers appear to have ceramic substrates. Regardless, I would love to know the tube diameter on the various 987 stock header primary tubes and the header outlet pipe.
2006 Boxster 2.7L stock header primary tube in straight section = 1.65" OD
2006 Boxster 2.7L stock header outlet tube = 2.15" OD
I would welcome similar measurements on known Cayman/Boxster S 3.4L stock headers. That would provide the final piece of the puzzle...
Blue-S
Old 01-16-2010, 05:21 PM   #11
Porsche "Purist"
Paul's Avatar
The Cayman S stock system on my 3.6 has 1.64" header pipes and the collector pipe is 2.21" The B&B system that I took off has 2.25" collector pipes.
Old 08-13-2016, 05:55 AM   #12
An old thread I know. The 987 3.2 headers are a 3 into one equal branch design rather than a tree arrangement on the 2.7 and 3.4 987 as pictured. Having dyno'd both designs on my 3.2 , I can confirm the 3.2 headers flow much better and give more power, they are also without the pop and crackle of the 3.4.
I'm interested in whether the 3.2 headers can be further improved by removing the ridges of weld on the flange at the inlet. There are some pictures i posed on the planet9 website under the articles section on decatting manifolds that show the two designs better.
What I can confirm is decatting either header doesnt work , it does give a better top end power figure but at the expense of the mid range peak torque figure.
berty987 is offline   Reply With Quote
