Old 12-22-2009, 07:32 AM   #1
Allen K. Littlefield's Avatar
High Temp Paint
Any recommendations for rotor hat paint? Prefer silver and I know that black grill paint is plentiful. Other colors recommended? Thanks in advance,
AKL
Old 12-22-2009, 08:09 AM   #2
I used the brake caliper paint to paint my rotor center (hat) and the ends of the rotor plates and the fins in between. I used just cheap, flat black, high-temp paint for the insides of the hat and the area between the rotor fins. Actually, I did the inside first, the sprayed the fins from the outside. It was a PITA, but it turned out great and still looks great. BTW, this was on my Firehawk, not the Boxster. Here's a pictures of the results (please ignore the dirty wheels) while the car was still on the jackstands.
That's the rear wheel where you can see the center of the rotor better. Here's the front wheel where you can see the edges of the rotor and the fins better.
A friend of mine did his on his 'vette in silver after he saw mine, and they turned out great. He wanted silver so they would just look brand new and clean. If you use the caliper paint, it will be high-gloss. Keeping them clean is a PITA though.
Mike_Yi is offline   Reply With Quote
Old 12-22-2009, 08:12 AM   #3
Don't buy aftermarket rotors. OEM rotors have painted hats.
Old 12-22-2009, 08:25 AM   #4
ChrisZang's Avatar
What would be the reason for that statement?
The Balo rotors I got at Pelican Parts work fine and made it through several DE days already w/o any fading etc.
Old 12-22-2009, 08:28 AM   #5
Allen, I'd just to go local parts store and ask for their high temp spray paints and see what colors they have. I'd also lay down a primer designed for metal and high temps as well.
Mike, I like what you did with the hats, but I don't think paint on the internal vents is a great idea. It will inhibit the rotor from releasing heat as well. Not a problem for normal street driving, but I wouldn't recommend it if you use the brakes hard.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
Old 12-22-2009, 11:23 AM   #6
Good point. I don't race that car at all, and my goal in painting them was rust inhibition.
Old 12-22-2009, 11:47 AM   #7
jcb986's Avatar
Vht
VHT makes rotor and caliper paint. Just replaced mine with Balo's. I soaked mine in a degreaser, then blew dry them using my air compressor, taped up the rotor surface and painted them. Hats and vanes. Try Auto Zone. Discount also carries it.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
