Old 10-29-2009, 05:46 AM   #1
Locks.......
I think if you disconnect the battery for a minute it will "reset" everything and you can then, use your remote. I am not 100% sure, if someone can chime in and verify????
Also, if you do this, you will need to have the radio code handy.
Dar01 is offline   Reply With Quote
Old 10-29-2009, 06:25 AM   #2
I have the same problem - lock mechanism broken.
AAA came and opened it for me, but I wouldn't want to make a habit out of it in fear of damaging the top frame. They used an inflatable bladder to separate the window from the frame, then slipped in a 'hook' to pull the door handle.
If I don't drive it for a couple days, it stays in the garage with the window cracked enough for me to get my arm in & pull the handle from the inside, just in case.
98 Arena Red 986
Stroked & Blown is offline   Reply With Quote
