Old 10-28-2009, 10:30 PM   #1
Doors will not unlock
I know that after a set period of time the car will not respond to the remote and you need to manually unlock the driver’s door. Unfortunately when I turn the key the doors do not unlock. The battery should be good and the security light on the dash is flashing. Any idea how I should unlock the car?
damiani2 is offline   Reply With Quote
Old 10-29-2009, 02:23 AM   #2
Need a little bit more info.. year
I had my DS door lock break inside the door.... tow to the dealer, 10 days and $800 later.
Parts had to come from "The Father Land"
'98 Artic Silver w/ Tip
vath2001 is offline   Reply With Quote
Old 10-29-2009, 05:46 AM   #3
Locks.......
I think if you disconnect the battery for a minute it will "reset" everything and you can then, use your remote. I am not 100% sure, if someone can chime in and verify????
Also, if you do this, you will need to have the radio code handy.
Dar01 is offline   Reply With Quote
Old 10-29-2009, 06:25 AM   #4
I have the same problem - lock mechanism broken.
AAA came and opened it for me, but I wouldn't want to make a habit out of it in fear of damaging the top frame. They used an inflatable bladder to separate the window from the frame, then slipped in a 'hook' to pull the door handle.
If I don't drive it for a couple days, it stays in the garage with the window cracked enough for me to get my arm in & pull the handle from the inside, just in case.
98 Arena Red 986
Old 10-29-2009, 06:38 AM   #5
locks
Thank you for the replies, it’s a 2002 boxster s. The windows were not working properly so I replaced the mechanism that the houses the sensors to the door handles. Could this locking issue be related to that replacement.
Old 10-29-2009, 09:44 AM   #6
It seems that it is easy to disconnect the locking mechanism while the door panel is off if you aren't careful, so this may very well be the case.
98 Arena Red 986
