Old 10-24-2009, 07:46 PM   #1
window Crack fixed - DIY with silicone!
Not just for boob jobs! Silicone will fix your plastic window too!
I had a small crack - about 1" long, right up next to where the window meets the canvass.
I ended up using some clear silicone sealant I got at Lowes. I partially lowered the top to take all the stress off the plastic, so I was able to get the "cracked" portions to come together...when the top was closed, the crack was separated a good 1mm or more....too wide to really seal up.
once the top was half way down, I was able to get the plastic window in a position so that the "tear" was "closed" and the edges were touching. I put a bead of siline on the outside...let it ooze into the crack, and let it sit. a few hours later I close the top just enough so that the window was flat, but not enough so it was fully closed...the window has "some" tension..but is not closed 100% nor latched.
so far it looks GREAT. you can just barely see the crack. i'll let it cure overnight and latch it shut i teh AM and see if it holds.
if this fixed my windows - wha ta deal. $3 for the silicone instead of $300-500 for a new plastic window! this ought ot last me a while. when my window finally does go..i may opt for glass..or a new plastic window sewn in..i found a reputable shop in San diego that will do it for $300 and will use clear or tinted plastic..my choice.
if your crack/tear is smack dab in the middle of your window, this may not work so hot cosmetically. i bet it would work to seal/fix it, but you'd see it more. the stuff dries clear but you CAN still see that there was someething there that I repaired..it's just that on my car b/c it's sooooooooo close to the edge of the window, you really don't notice it.
besides, 90% of the time I'm out in my car, the top is DOWN!
the stuff i used it sold by loctite. it just clear silicone adhesive.
_____________________________
Cars:
2007 MDX - Wife's mommy mobile
2006 RL - My daily driver
2000 Boxster - Ocean Blue Base 5spd on Black Full leather. 18" wheels and M030.
Boxster mods I've added: Rear speaker kit, Painted Calipers, Painted Bumperettes, Painted Center Console, 987 Shifter Assembly, 3 Spoke Steering Wheel, Clear side markers, 03+ rear lights, de-snorkeled.
23109VC is offline   Reply With Quote
Old 10-24-2009, 09:06 PM   #2
I hope it works for you but I have a hard time believeing silicone has the tensile strength to hold for any length of time. Let us know and good luck.
SoCalKen is offline   Reply With Quote
Old 10-25-2009, 06:01 AM   #3
nice!
box321 is offline   Reply With Quote
Old 10-25-2009, 02:36 PM   #4
It has worked for me for the last few months and that is what I have been suggesting to people on here since I tried it.
I'll take my Guns, Religion, and Money; You can keep the "CHANGE" B.O.!!
SO, GROW A PAIR NANCY AND DRIVE IT LIKE YOU STOLE IT!!
http://i826.photobucket.com/albums/z...Main/MyBox.jpg
mptoledo is offline   Reply With Quote
Old 10-26-2009, 08:09 PM   #5
after letting the silicone cure overnight...i cranked the window back up, locked it in place..and........................... IT HOLDS!
the silicone has held the crack together...for at least 24 hours!
and honestly, I did NOT use that much silicone. i used a VERY small bead of the stuff as I did not want huge globs of stuff all over the window..i figured start with a small amount and if it didn't hold, then i woudl redo it with "more".
as it's turned out, my minimal applicaiton has held up just fine.
I just saved myself having to spend $300-400 on a new plastic window...for a while. good...i want a PSE or NHP muffler and GT3 bars....gotta save for those! and buying new plastic windows just eats into the "fun" budget!!!!
Cars:
