Old 05-24-2009, 06:04 AM   #5
07 Carrera S Cab
Boxtaboy's Avatar
Originally Posted by jrblackbox
Mike, Thanks for the link, that's what I needed, next week I will pick up that switch and attempt it. Jim
Jim, while it does give you more access to the switch when you remove the seat, it really is not necessary. Take a look at Pedrosgarage instructions I posted below.
When you remove your seat, there is always the slight chance that you either strip a bolt, or forget to take the ignition key out, and your airbag light ends up going on, so try it without taking the seat out first. Pedro has replaced a bunch of them and does not recommend removing the seat.
Instructions found here:
http://pedrosgarage.com/Site%203/Replace%20Ignition%20Switch%20%20%20.html
