Old 05-10-2009, 10:47 AM   #1
If you look at the inside of your trunk lid right above the cap you might find some white residue or some condensation. If thats the case you need a new cap. If not then you probably can live what you have until it fails.
01 Boxster - Lapis Blue - Aerokit II Daily Driver.
98 Pontiac sunfire - Winter beater- TRADED IT IN FOR 200 DOLLARS
2010 Honda Civic Coupe - Gunmetal Grey - Lease ended and returned
2011 Mercedes Benz GLK350 - Gunmetal Grey
ramo80 is offline   Reply With Quote
Old 05-10-2009, 06:28 PM   #2
Smile dumping coolant
i have a 99 boxster that kept dumping coolant and i finally resolved it b y changing the reservior, it had a small leak and was a common issue in the boxster.
kjohnson986 is offline   Reply With Quote
Old 05-11-2009, 05:09 AM   #3
Allen K. Littlefield's Avatar
Did you notice any water pooling up under the reservoir? Or was the leak so small that the amount of coolant leaked immediately evaporate? I had no water under my tank so I think the cap will be the answer. Thanks for you contribution.
AKL
