Old 11-25-2008, 07:21 PM   #1
HELP Rain water leaks into cabin from side window seal
Hi everyone hope you can help me otherwise my car is going to stay a spa!
Porsche service recently replaced the LHS rear foam driptray and red knob arm under the soft top (as well as realigning the top after wards).
Since then the top has started leaking a large amount from both sides of the car when being washed and in the rain (with the water pooling in the foot wells).
Sitting in the car during recent rains I watched water pour/leak through the channel joins in the attached photo (sorry my camera is hopeless so I stitched a few photos together of others and have yellow arrows pointing to the joints).
Porsche realigned the top again but that did NOTHING to stop the leak.
Has anyone else experienced this?
Or can anyone help/advice what to do to fix it?
Please help!
Sam
samlad is offline   Reply With Quote
Old 11-26-2008, 06:10 AM   #2
Is the top as tight as before?
This is something that the dealer ought to be able to prove to you they have aligned the top correctly before the car leaves the shop. Just a hose with the car parked outdoors should be test enough.
Is it possible that a secondary effect of the problems you had that caused the earlier repairs caused the frame of the top to be bent?
Are the side windows making firm contact with the weather stripping all around the side windows?
Old 11-26-2008, 09:04 AM   #3
edevlin's Avatar
Hey, my passenger side window leaks where it does not make a good seal on its back side. I only see this in a heavy rain, and not when driving just when sitting in a good downpour. I dont have any ideas what to do about it, the window looks like it is comming up all the way and the seal seems fine along the top of the window, it is the rear part of the window that has a small gap, or at least a poor seal.
Ed
My Car Webpage
Old 11-26-2008, 10:03 AM   #4
Lil bastard's Avatar
Until you get it sorted, be sure that the alarm module under the driver's seat does not get wet...BIG bucks to fix it!
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 11-26-2008, 03:09 PM   #5
mikefocke, the side windows have a great seal all the way around with not even a drop (it's just from the hood rubber seal gaps that water is coming in).
I took it back the third time for the roof realignment, making it tight as hell (requires 2 hands to latch the top on now) BUT, still getting leaks from those spots.
The dealer did a hose test and it looked good while there but typically once you get away and on it sitting in the rain at home, beads of water start to appear and leak (as though the channels at the top are overwhelmed by constant watering).
Any suggestions as to why this is continuing under constant rain?
Lil bastard, the whole mess started exactly with that issue, when I had the foam tray replaced as it was ripped and there was water under the seat. Happy to say, no longer the problem but as an additional outcome my top seals now leak.
For this fear I've also been inspired to get this car WATERTIGHT so I've taken out all the carpet and with a microscope making sure there is nothing else wet going on! All looks good, EXCEPT the top seals!
Others advised that the "top cables tension" could be an issue? If so what and where is that?
edevlin I feel for you as I am experiencing that as well. Removing the carpet I noticed that there is a very small amount of water (that pools in time) bypassing the foam drip tray. But for you if you say it is a window seal issue have a look at this http://www.renntech.org/forums/index.php?showtopic=22526
Let me know if that helps or how you overcome it as I may do with a similar fix?
