Is the top as tight as before?
This is something that the dealer ought to be able to prove to you they have aligned the top correctly before the car leaves the shop. Just a hose with the car parked outdoors should be test enough.
Is it possible that a secondary effect of the problems you had that caused the earlier repairs caused the frame of the top to be bent?
Are the side windows making firm contact with the weather stripping all around the side windows?
