Old 05-30-2008, 01:54 PM   #1
Transmission Fluid Change
Hi guys, is a transmission fluid change an easy DIY job? I just got an estimate from the shop and they are quoting me $420 for a Transmission Service.
I have changed my own brake pads and oil before on the Boxster, so is a transmission fluid change much more difficult than either of those?
2001 Boxster
2014 Toyota Tundra
"Its Craptacular" - Bart Simpson 1997
joshua6060 is offline   Reply With Quote
Old 05-30-2008, 03:23 PM   #2
Lil bastard's Avatar
Check my DIY : http://www.986forum.com/forums/showthread.php?t=15522&highlight=Tiptronic
Much less than you were quoted, incl. buying the fluid pump (which is the only one I'd use - holds all the ATF at once), 17mm Hex Bit, Sealant, Gasket and Filter (s/b changed every 45k mi.).
I'd definitely say it's a pretty easy, though time consuming DIY - I'd rate it a 3/10. PM me if you have any questions
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 05-30-2008, 03:26 PM   #3
Got rid of my replies when I saw Lil Bastard's DIY - that's the way to go.
Paul B. Anders / Phoenix, AZ
1970 Porsche 914 / 2003 Porsche Boxster / 2009 Honda Fit Sport Auto
pbanders is offline   Reply With Quote
Old 05-30-2008, 06:39 PM   #4
Std Transmission
Ok, so has anyone changed the fluid on a Std transmission?
I did this once on my 1991 300ZX and it was simple. There is a drain plug on the bottom and a fill plug on the top. the only trick was creating a pump like device to push the fluid into the transmission fill plug. I created a device with 2 hoses one that hooks to a compressor (low PSI) which goes into the bottle and another hose that comes out of the bottle into the transmission.
-Steve
chitowndad is offline   Reply With Quote
