Old 05-09-2008, 09:54 AM   #1
Do the boxsters come with limited slip?
just wondering if our boxsters come with limited slip or was that an option... thanks
waynes986 is offline   Reply With Quote
Old 05-09-2008, 09:55 AM   #2
None came with it, but I think it was an option only on the '97, in some sort of sport package that quickly went away. Too bad, as the Porsche LSD is better than the aftermarket units.
Todd
2005 Boxster S - Atlas Grey/Black, PASM, Sport Chrono, Bose
2006 Infiniti M35 Sport
2007 Cadillac Escalade (tow vehicle with bling)
'00 Boxster - 2.7l w/FVD ECU tuning, Moton double adjustable suspension, custom stainless headers, lightweight flywheel, dual Magnaflow mufflers, 18" CCR wheels, 911 front brakes in front, Boxster front brakes in rear, full welded cage.
http://www.epiqautosport.com/images/epiqtoddavatar2.jpg
EPIQTodd is offline   Reply With Quote
Old 05-09-2008, 10:32 AM   #3
i was looking at a car and one of the options on it was #224 automatic limited slip... what's that it was in an 00 boxster base
Old 05-13-2008, 09:41 AM   #4
Yeah Wayne, thats it, the option code for the limited slip diff is M224
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 05-13-2008, 10:29 AM   #5
Oh goodness.
No, boxsters were not available with a limited slip. What they were available with was traction control / PSM and the electronic brake differential (224). It's basically a way of using the four-channel ABS system to apply the brakes to a spinning wheel. It works with PSM / TC disengaged.
In my experience with it, it doesn't work so great.
John V is offline   Reply With Quote
Old 05-13-2008, 10:47 AM   #6
Yes. According to my option codes under my hood I have limited slip on my 2000 Boxster S.
http://i25.tinypic.com/20aq3wn.jpg http://i26.tinypic.com/2zguetx.jpg http://i28.tinypic.com/2jdi1ok.jpg
2000 Boxster S: 18" Turbo wheels w/color crests, Litronics, Onboard Computer, Traction control, Cruise, Painted rollbar, Leather interior, Aluminum package, headlight washers, Porsche GT3 seats, windstop, Hi Fi six speaker amp package, DSP, CDR 220, Limited Slip, side airbags, BK Rollbar extender.
2000SoCalBoxsterS is offline   Reply With Quote
Old 05-13-2008, 10:50 AM   #7
Strange, I thought Porsche only allowed a limited slip on the 911. I wonder why more people didn't spec this option for the boxster if it was in fact available?
Old 05-13-2008, 11:23 AM   #8
Porscheectomy
There was NEVER a mechanical (re. true) limited slip differential offered for the Boxster. They are available, however, through quaife and guard transmissions.
The electronic based limited slip that comes with PSM (and traction control before PSM was offered) does not function in the same way as a mechanical unit.
Old 05-13-2008, 11:25 AM   #9
Awesome, im going to look for limited slip equiped trannys at salvage yards now...
haha jus messing with you blue2000s
Carlos J Cazares
Old 05-13-2008, 11:29 AM   #10
I gotha. Yeah, in my opinion calling anything that brakes the slipping wheel a limited slip is a stretch.
Old 05-13-2008, 11:32 AM   #11
Yeah porsche should have worded that option differently.... just like how ebay sellers selling knock off stuff always add the word "Style" to the end of the discription in tiny print...
example: TWINTURBO style FRONT BUMPER
Carlos J Cazares
Old 05-13-2008, 11:42 AM   #12
Porscheectomy
Let us know what you find out there
Old 05-13-2008, 11:45 AM   #13
I found a Glass "style" Rear Window kit for my boxster laying in the street...
Carlos J Cazares
Old 05-14-2008, 07:13 PM   #14
Porsche "Purist"
Paul's Avatar
But, that's what the Porsche differential clutch based LSD does.....
1987 924S. 2002 996TT. PST-2
Old 05-15-2008, 04:57 AM   #15
You don't, in the typical definition of the term. It's a brake-based system controlling an open rear differential.
With proper programming I suspect it could work pretty well. But Porsche's programming isn't that good.
Old 05-15-2008, 10:59 AM   #16
No a real limited slip doesn't brake anything. Most use a clutch, a gear or fluid inside the diff to transfer torque from the slipping wheel to the non slipping wheel.
Old 05-15-2008, 12:07 PM   #17
I think they are doing a ltd slip group buy over at CaymanClub.com.
Mike
PCA since 1970
70Sixter is offline   Reply With Quote
Old 05-15-2008, 03:55 PM   #18
Porsche "Purist"
Paul's Avatar
Porsche as I stated in my post uses clutches to brake the spinning wheel and transfer torque to the other wheel.
Old 05-15-2008, 04:03 PM   #19
Porsche "Purist"
Paul's Avatar
from: http://auto.howstuffworks.com/differential4.htm
Clutch-type Limited Slip Differential
The clutch-type LSD is probably the most common version of the limited slip differential.
Image courtesy Eaton Automotive Group's Torque Control Products Division
This type of LSD has all of the same components as an open differential, but it adds a spring pack and a set of clutches. Some of these have a cone clutch that is just like the synchronizers in a manual transmission.
The spring pack pushes the side gears against the clutches, which are attached to the cage. Both side gears spin with the cage when both wheels are moving at the same speed, and the clutches aren't really needed -- the only time the clutches step in is when something happens to make one wheel spin faster than the other, as in a turn. The clutches fight this behavior, wanting both wheels to go the same speed. If one wheel wants to spin faster than the other, it must first overpower the clutch. The stiffness of the springs combined with the friction of the clutch determine how much torque it takes to overpower it.
Getting back to the situation in which one drive wheel is on the ice and the other one has good traction: With this limited slip differential, even though the wheel on the ice is not able to transmit much torque to the ground, the other wheel will still get the torque it needs to move. The torque supplied to the wheel not on the ice is equal to the amount of torque it takes to overpower the clutches. The result is that you can move forward, although still not with the full power of your car.
Old 05-15-2008, 06:01 PM   #20
Porscheectomy
Not on the Boxster.
