Old 04-05-2008, 01:30 PM   #5
There Is No Substitute.
rick3000's Avatar
Here are the instructions for the OEM way:
http://www.dennisvogel.com/heatedseats/index.html
You might be better off to look into an aftermarket kit, then wire it with the OEM switches, to the switched 12V power under the center console. It may not be OEM, but you could probably do it for less that $300 or so, vs., $2000.
