Old 02-16-2008, 03:29 PM   #1
Squrilly rear end in rain - new tires, bad wheel bearing
Hi Guys, its been a rough week for the Boxster, had a new battery installed and new HRTZ II Tires, when I picked up the Boxtster from the Tire shop, the guy told me that I had a bad rear wheel bearing and its possible that it could be a rear hub making the noise also. The noise isn't too loud, but slightly noticeable. I heard the noise before but I just assumed it was from the bald tires..... anyway since picking up the Boxster I had driven the car in the interstate 3 times, twice on clear days and 1 day when it rained, on the rainy day, I noticed that my rear end was very squirlly fortunately as I slowed down to a speed that felt much safer and less squirlly (35mph) as I hit traffic. Does anyone have any idea if the bad wheel bearing would cause my rear end to feel less stable in the rain? Certainly it can't be because of the tires because they are 3 days old...... Any comments would be greatly appreciated
joshua6060 is offline   Reply With Quote
Old 02-16-2008, 03:42 PM   #2
this is caused by excessive toe. you could have excessive toe either because the alignment is not proper or because a bad wheel bearing is allowing the toe setting at one or both wheels to change as you drive. wheel bearings are a common wear item on this car; i'd replace the bearing at the noisy wheel and get your alignment checked.
insite
'99 Boxster
3.4L Conversion
Old 02-16-2008, 03:43 PM   #3
bmussatti
Posts: n/a
Well, here are a couple things to consider:
1) It will take about 200 miles for the tires to "scrub" in.
2) You are using non Porsche approved tires, so you should also expect less than optimum performance.
3) What is the air temp there now?
4) Check you tire pressures. Tire shops usually over inflate tires. You might get better grip with tire pressure adjustments.
Old 02-16-2008, 03:48 PM   #4
certainly all good stuff to check, but if you had to slow down to 35mph to feel safe, your toe is tweaked. with excessive toe, your tires are either pointed toward each other or away from each other. when it rains, the decreased grip allows one or both tires to drag a bit rather than roll. this causes instability particularly in the rain. very uneasy feeling.
insite
'99 Boxster
3.4L Conversion
Old 02-16-2008, 04:00 PM   #5
EE3racing
Posts: n/a
Are those tires Sumatomo? In either case my 2 cents.
When I was a lad, I had a tricked out Fiat X19, I was totally taken with the mid engine superiority design. So much so that I didn't respect the properties of wet pavement and took an unexpected spin on an off ramp; thank god no other cars were around. As it turned out, I was glad to learn my lesson in a car. Years later during my motorcycle phase, I learned that rain raises, oil droplets and other road deposits in the street. In short, pushing any vehicle with any tires in these conditions is a bad idea. Having said that, tire pressures, compounds used and tread design all contribute to performance. Making a great dry tire sacrifices wet performance and vise versa. Check out the tire rack website sometime, it has some great information regarding these principles. Of course if the geometry of the suspension is off everything I said means nothing. IMHO, a wheel bearing wouldn't cause this type of erratic behavior.
PS if you really want to experience your car, upgrade the rubber. My dealer thought he was doing me a big favor putting two new sumatumos on the car when I bought it. I ditched those tires a month later with a ton of tread on em and was glad I did.
Old 02-16-2008, 04:06 PM   #6
Yeah Sumatomo HRTZ II's, I got what I could afford right now, Looking less than a month away from having the 75,000 mile check up so I know I'm going to take a hit on that so I got the 2 rear tires I could afford right now.....I wasn't pushing the car at any crazy speeds in the rain, I was driving 60 on the interstate. Felt unsafe and unsure so I slowed up to 35mph in the right lane then hit traffic 1/4 mile after that.
Old 02-16-2008, 04:34 PM   #7
EE3racing
Posts: n/a
That doesn't sound like the rubber at all. I wasn't trying to put the tires down, i know all too well what it's like to be on a budget. i guess all I was saying is good rubber is a fantastic performance upgrade, I think as important as HP any day. Do you know if your car has ever been hit?
Old 02-16-2008, 04:39 PM   #8
Yeah the Boxster is putting a hit on the wallet right now, so i'm just trying to watch the dollars when I know the hits are coming back to back.
I am unaware of the car ever being hit, I purchased it as a Certified Pre Owned Porshe and I checked the car fax report(I know that provides little assurance but thats the facts)
Old 02-16-2008, 04:54 PM   #9
EE3racing
Posts: n/a
If you have a warm garage and a powerful light you can do some self detective work. Look for any evidence of overspray on vents, molding, fender wells. Look across the paint for any tiny scratches that filler leaves behind. Look at the seams of the panels, make sure they have the same spacing, an example would be the hood line seams to the fender. Look for anything that is asymmetrical from one side to the other, compare the fender liners, and so fourth. The more you know the easier it may be to track down the issue, it's like being a detective, a process of elimination. Even if it has been hit, it's not the end of the world, but knowing it will assist you in deciding what to rule out. good luck, with patience and determination Ii know you will get it sorted out. My car originally had sport classics on it, some guy talked the dealer into swapping his turbo twists in a deal, I had to have my wheels trued and corrected as three were slightly bent, it's part of the reason I chromed them. You can sort out most any car all it takes is determination and a fat wallet.
Old 02-17-2008, 12:04 AM   #10
did you get the same size tire that you had before?
the sumis are not a great tire, but they are not horrific either, and you should be able to drive at least within your limits on them.
check pressures. if they are too high and to a lesser extent if they are too low. it will be a bit un-nerving.
and yes, they will take a little while to scrub in.
what kind of tires do you have up front? if you have a really grippy front tire, with these on the rear, that would exaggerate the issue.
FWIW, i recently put on new tires. the fronts got lots wider. and i didn't get my full set of spacers yet, so i was spaced way out up front, and not in the back, and my toe was still way off, in the rear. but the car drove just fine on my old tires so i didn't bother with the toe yet.
with the new tires. re01-r, which is a GREAT tire BTW. the back end was all kinds of unstable.
i put the full set of spacers on front and rear, and i changed the toe by 1/8 per side. its super stable now. before driving at 70+ was a little sketch and the back end felt like it was about to whip out at any time. i was at 1/16 out on each side, for a total of 1/8th out. which is A LOT! but i was playing with settings to get the back end to be able to come around for autox. I am now 1/8 total toe in.
follow the advice above, but just know that alignments make a big deal. and always try to have matched tires front and rear.
GL.
Benny
Benny986 is offline   Reply With Quote
Old 02-17-2008, 04:34 AM   #11
If the tires had less than 50 miles on them when you encountered the rain, then I vote for mold release.
Mold release is sprayed on tire treads at the factory. It is a slippery liquid that makes it easier to get the tire out of the mold. It is usually left on the tire and it is really only practical to get it off by putting some mileage on the tire. This is why you hear racers talking about "scrubbing in" race tires.
Mold release (or ArmorAll on the tread) will definitely effect the wet handling of the car. Also, had this been the first rain in your area in a while? If so then there might have been a healthy film of oil on the road as someone else suggested.
I say don't worry about this one incident. You did the right thing by slowing down until you felt safe.
But I do think you should have the wheel bearing looked at by someone knowledgeable (in general I am not impressed by tire shops). Try to find yourself a GOOD Porsche mechanic in the area. Contact your local PCA and ask around. A GOOD mechanic is worth far more than his hourly rate and a mediocre mechanic is worth far less no matter how little he charges. Also dealerships vary in the quality of their service departments. Ask local Porsche drivers which one is best.
Regards,
Alan
renzop is offline   Reply With Quote
Old 02-18-2008, 11:11 AM   #12
Not sure about your other issue, but I had a bad Rear Bearing on my 02 S and it got to the point that I could not go above 40 without hearing the loud rumble. I normally would have taken it to my porsche mechanic, but they were asking way too much. I ended up going to my local Firestone who does work on my pathfinder and walla, $300+ less and as good as new. This price also included the lifetime alignment...my regular porsche mechanic & dealer didnt even include that in their price estimate.
Just an option when you decide to get that work done.
'02 Bassalt Black Metallic "S" with grey top and interior; 6 speed, Litronics, bose, heated seats, & 18" sport classic II wheels
'00 Blue Yamaha YZF600R
jvmoney is offline   Reply With Quote
Old 02-27-2008, 03:08 PM   #13
I just had my rear wheel bearing replaced at the dealer for $700. I will not do that again.
The dealer just told me that they have special tools that only they have to do the alignment as well...after they tried to sell me new Pilot Sports for $300 more than I see them locally.
I wonder what the dealer is good for if local shops can do better for less...
WOW!
eVoMotion is offline   Reply With Quote
Old 02-27-2008, 03:13 PM   #14
WOW!
$700!?!?!? including or excluding alignment? either way, you got hosed. with regard to the 'special tools' for the alignment: they're full of crap. an alignment on a boxster is pretty routine.
insite
'99 Boxster
3.4L Conversion
Old 02-27-2008, 03:13 PM   #15
Lil bastard's Avatar
+2 (or is it 3) for scrubbing them in. "Be careful out there"
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 02-27-2008, 03:15 PM   #16
They're probably talking about the drifts and the press to swap the bearing. Same as the NAPA machine shops have. Agree in the Hose Job though.
1976 BMW 2002
1990 BMW 325is
Old 02-27-2008, 03:20 PM   #17
Alignment tools...after I told him no to the tires, he said that he HIGHLY recommended (that I spend some $$ at least) that I go with them and named the special tools they have to use. Madness.
And yes - ouch! On the $700...wheel bearing, no alignment. I was a dealer virgin...they taught me well.
Thanks to this forum...I have learned a great deal.
Old 02-27-2008, 03:55 PM   #18
i would have raised hell. on another note, i'm running a special this week; i'll install new wiper blades for $145. per side. :-)
insite
'99 Boxster
3.4L Conversion
Old 02-27-2008, 04:02 PM   #19
Funny thing, Im also having a special till the end of the month... Refilling brake light oil for $449.99, Turn Signal oil is extra.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 02-27-2008, 04:48 PM   #20
nice! btw, CJ, your flex capacitor just arrived.
insite
'99 Boxster
3.4L Conversion
